Old 31st August 2006, 08:57 AM   #1
100db is offline 100db  Thailand
Question Resistor from Pin + (7) to ground in inverted GC
Hello all,
For the inverted LM-3875, I need your advice on the different between having ...
1. Resistor between Pin + (Pin7) to ground
2. Resistor in parallel with 0.1uF cap to ground and...
3. Connect pin + directly to ground ?
How is it work, and which one should give the best sounding ?
Ball
Old 31st August 2006, 09:31 AM   #2
pinkmouse's Avatar
I would go for a direct connection, but it's simple enough to test all three and see which you prefer.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 31st August 2006, 11:12 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Its a nice story, really:
Part of the amp DC output offset is caused by the difference in DC bias at the two inputs.
Those two inputs need a small DC bias current to work (base current of input transistors). So if the DC impedance seen by those bias currents at the two inputs is different, the DC voltage resulting from current times impedance is also different and will cause output offset DC (the input DC difference will be amplified by the amp closed loop gain of course).
So, very often you see the pin 7 resistor as being equal to the DC resistance of the - input to balance out the offset. The DC resistance seen at the - input is the parallel value of the two resistors in the feedback network (if it is DC coupled, else it is just the value of the main feedback resistor).
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 1st September 2006, 12:28 PM   #4
Thanks Al, Thanks Jan
So, if I don't have any problem with DC offset... then it's O.K. (better) to connect pin + directly to ground.
Am I understand this correctly ?
Will try it out this weekend.
Ball
a resistor to ground? lanchile07 Chip Amps 11 23rd November 2007 02:16 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
resistor values for lifting ground AND LED cbutterworth Tubes / Valves 1 24th January 2007 11:46 PM
Resistor Value on Inverted GC 5150ed Chip Amps 9 2nd August 2006 12:57 PM
Why does the inverted gainclone have a resistor at the output goldyrathore Solid State 10 12th April 2005 11:36 AM
Page generated in 0.08087 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
