| Chip Amps Amplifiers based on integrated circuits |
http://www.national.com/an/AN/AN-898.pdf "Of the multiple ways to set the mute current and utilize the mute function, the use of a regulator can continuously control the amount of current out of the mute pin. This regulation concept keeps the attenuation level from dropping below 0 dB when the supply is sagging. More information about mute circuit configurations will be provided later in a future application note." Has anyone tried this approach with regards to the mute pin? |
#2 |
You could use the LZ vresion of the popular LM317/337 series --- the mute pin only takes a few milliamps.
jack |
#3 | |
If you are worried about sag, use a R-C-R setup with say C=100uF. This will prop up the mute current during transient sags.
Glenn. |
#4 | |
http://www.rane.com/pdf/ma3sch.pdf An unusual way to control the current of the mute pin. Can anyone explain how the circuit works? Regards Marco |
#5 | |
#6 |
You can pull more current from the Mute pin than 1mA. If you are really worried about it then set the mute resistor to 10K. Then the amp will ALWAYS be in PLAY mode because before the Mute current can drop low enough the under voltage will kick in and shut down the amp anyway. It won't hurt anything to pull out 3mA when fully on. Or pick a point in between, say 20K so supply has to drop well below +/-20V to lose enough current to affect anything.
-SL |
#7 | |
Glenn. |
#8 | |
Think of Q20 as a constant current source. D26 (a red LED) acts like a zener of about 1.6V. Subtract the Vbe~=0.6V of Q20, leaving 1V across R67. A constant current of 1V / 2Kohm = 2mA will flow through it. R70 and R58 act as a voltage divider across the V- power supply, in the ratio of 4.42/(4.42+51.1) = 0.0796. When this divider reaches a voltage equal to the Vbe of Q19 plus the V across R67, then Q19 will begin to conduct thru the mute pin 8. The Vs at which the conduction begins is Vs * 0.0796 = 0.6 + 1, therefore Vs = 20.1V. As Vs continues to rises to 32 volts, the voltage divider will rise to 32 * 0.0796 = 2.55V. Subtract the Vbe of Q19 giving 1.95V across R67. There is no longer sufficient Vbe on Q20 for it to conduct, so it no longer contributes any current through R67. At this stage the current thru R67 is 1.95V / 2Kohm = 0.975mA, which funnels up thru Q19 into the mute pin. C45 will slow down the current rise somewhat. A neat circuit, but one simple resistor and maybe a capacitor can do a very similar job.
Glenn. |
#9 | |
The overall circuit behaviour is the same even with this slightly different interpretation of Q20.
Glenn. |
| lm3886 no mute | rtill | Chip Amps | 21 | 29th August 2009 05:43 AM |
| LM3886, mute question... | CJ900RR | Chip Amps | 2 | 9th March 2008 03:28 PM |
| LM3886 Mute | richie00boy | Chip Amps | 6 | 18th August 2004 11:26 AM |
| lm3886 mute LED | blabley | Solid State | 1 | 30th May 2002 05:51 AM |
| Page generated in 0.12142 seconds (79.03% PHP - 20.97% MySQL) with 11 queries |
