how to Using single secondaries transformer for snubber psu - Page 2 - diyAudio
Old 9th September 2006, 01:20 PM   #11
kvholio is offline kvholio  Netherlands
kvholio's Avatar
However ALL the diagrams need further work on the grounding.
I agree. Strangely when you wire up the pcb's from chipamp.com the way you are "supposed to" you end up with a grounding-scheme exactly like in the posted schematics.
AndrewT is spot-on with his recommendations, i strongly suggest you follow them.
With kind regards,
Klaas
Old 10th September 2006, 09:20 AM   #12
Hi Kv,
I have never built a chipamp or one of it's PCB mounted PSUs.
Have you tried to compare the hum/buzz performance of the chipamp PSU with a hardwired version matching the good audio grounding recommendations?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th September 2006, 09:46 AM   #13
frugal-phile(tm)
planet10's Avatar
Originally posted by triast
So which one is correct?
I drew the BrianGT's maps.... i've always had trouble with the orientation of diodes... the top one is correct (at least that is the one in my most current master file) -- the 2nd one should never have gotten on his website -- it was a beta that didn't pass QC.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th September 2006, 10:04 AM   #14
frugal-phile(tm)
planet10's Avatar
My BrianGT/Peter Daniel GC was dead quiet... grounds came together on the amp board and the filte caps are right next to the chip....
I don't know if he is the origin, but this was Thorsten's recommended scheme when he 1st introduced the start of the "official" GCs on the Full Range Forum.
dave
Old 10th September 2006, 10:14 AM   #15
kvholio's Avatar
Hi Andrew, i didn't try the psu-pcb's.The high-capacity gc's i built always had ps-ground simply between the two big c's.
Keeping the gnd's separate at the psu, and joining them at the amp's pcb didn't make any sense to me, so i didn't try it.
I never experienced any hum-problems with my gc's .
It might be fun to try though and compare performance.Need some new rectifiers to do this.(don't ask how i blew up the old ones- i'm a klutz).
I will do the experiment and report back on this
This picture shows clearly that ps-gnd is not at the psu-pcb from chipamp.com:
http://www.briangt.com/gallery/snubber/ps_020
planet10, were you using these psu-pcb's with your gc's ?
With kind regards,
Klaas
(waiting on my ati-case for the ksa-clone )
Old 10th September 2006, 10:28 AM   #16
frugal-phile(tm)
planet10's Avatar
Yes.
Old 10th September 2006, 10:43 AM   #17
kvholio's Avatar
Thanks for the info Planet10. btw, your hum-free result doesn't surprise me.
i just see no reason to keep those gnd's separate at the psu.
Guess i'll have to try and see how it works out.
With kind regards,
Klaas
Old 10th September 2006, 11:07 AM   #18
Hi Kv,
Can I assume the important word is HAD and that you now HAVE the audio ground elsewhere?
regards Andrew T.
Old 10th September 2006, 11:40 AM   #19
kvholio's Avatar
nope.
I HAVE my ps-ground(should i say 0V common ?) between the big c's and i HAVE my audio-ground elsewhere.
With kind regards,
Klaas
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 07:39 AM
two single secondaries, two rectifier boards lm4780 kit gbolly Chip Amps 5 23rd August 2008 08:59 AM
transformer secondaries question endia Chip Amps 12 26th January 2005 08:41 PM
Trafo- 225VA , single 117V primary, Dual 40V secondaries Illusus Swap Meet 3 11th December 2003 05:07 AM
Copyright 1999-2017 diyAudio
