| Chip Amps Amplifiers based on integrated circuits |
I am building a project running a puredata sound program on a mac mini- the outputs are connected via firewire to the eight channels out on a presonus firepod. The speakers I am using are small: 1W 8ohm, and I need to build compact amps for each speaker. Can anyone suggest some designs? I know very little about amp design.
Thanks Greg |
#2 |
try Philips's TDA7052
#3 |
Thanks- I will give it a try.
greg |
#4 |
National Semiconductor has a ton (and I mean ton) of 1W/8ohm parts (their Boomer line) that run from 5V. You can simply use 3xAA batteries or even 4xAA if NiMH and run them from a little battery holder. They even have parts in the old SOIC package so you can easily put the sucker on a bread board and test it out first or use a socket. Just do a search there and you'll find all you ever wanted. I think they might get as high as 3W for a 4 ohm load but that is probably a 10% THD+N number so not really useable. Might want to check them out.
-SL |
| Help/advice needed | jjs4028 | Multi-Way | 13 | 11th October 2006 10:16 PM |
| Advice needed for amp design | ifrythings | Solid State | 26 | 13th May 2006 01:17 PM |
| My first DIY DAC, advice needed | mr_push_pull | Digital Source | 19 | 30th August 2005 04:16 AM |
| advice needed | jimbones | Full Range | 6 | 9th November 2004 07:40 PM |
| Page generated in 0.06790 seconds (74.11% PHP - 25.89% MySQL) with 10 queries |
