Self adhesive copper track Gainclone - Page 3 - diyAudio
Old 30th August 2006, 05:31 PM   #21
ash_dac is offline ash_dac  United Kingdom
Originally posted by AndrewT
most semis specify 300degC for 10seconds maximum.
If you delay by trying to heat up a pin with too low a tip temperature then heat transfers to the internals and risks damage.
If you can get a succesfull joint at 330degC in 5 seconds you end up with LESS heat inside the semi and less risk of damage. But you must be quick.
Sounds like when I used to solder nicad batteries back in my radio controlled car days!
Old 30th August 2006, 05:47 PM   #22
Sherman is offline Sherman  United States
My soldering skills took a quantum leap when I abandoned my hotstick type iron and bought a soldering station with adjustable temperature.
Another tip, buy the right solder. I'm not talking about lead-free, silver blah blah, but the right diameter. (Smaller is usually better unless you are doing plumbing repairs!)
--Sherman
Old 3rd September 2006, 01:49 PM   #23
http://www.mhennessy2.f9.co.uk/artic...xperiments.htm
Is the scapel / graph paper and heat method worth pursuing ?
Old 7th September 2006, 09:11 AM   #24
Just a thought.
Seems to me it would be much, much simpler to just p2p. You can p2p an LM3886 in less than an hour.
Poor stereo mix? Switch to mono! Perfect.
Old 7th September 2006, 10:12 AM   #25
I totally agree on the solder diametre tip.
I used to use leaded solder but then switched to some lead free silver solder. Worked ok but i had a few issues getting used to it. I then mention it to my Dad who gave me a load of old leaded solder. I was a fair bit fatter that most solder i had used before. I thought being lead it would flow really nicely but the added diameter made it i nightmare. You simply couldnt get enough heat energy into the soldering iron tip to make to work properly.
I then switched back to my much smaller diameter leadfree and it flet absolutely brilliant in comparison.
MY advice is that the diameter has a much greater effects that solder type.
Phil
Old 8th September 2006, 03:34 PM   #26
Originally posted by davidlzimmer
Just a thought.
An hour!
My heatsink has arrived (17" long and 4.75" wide). I need to chop it up a bit....
Old 9th September 2006, 05:12 PM   #27
Default Push on blades ?
Would it be possible to crimp male push-on blades to the LM3886 for prototyping? (they would need to be aligned to prevent shorts)
Adhesive for ESL panel repair 405man Planars & Exotics 7 26th June 2014 07:24 PM
removing old adhesive for a refoaming ichiban Multi-Way 3 7th August 2008 01:49 AM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
pcb copper laminate glue adhesive gain wire Parts 6 12th February 2006 12:20 PM
Anybody knows where t oget cheapie self-adhesive copper tape?? li_gangyi Everything Else 8 13th December 2003 04:57 AM
Copyright 1999-2017 diyAudio
