Self adhesive copper track Gainclone
Old 24th August 2006, 06:29 AM   #11
ash_dac is offline ash_dac  United Kingdom
Originally posted by AndrewT
single core 0.6mm is ideal for all the low to medium current interconnections. Very short lengths (<5mm) left without insulation. Longer lengths with insulation kept on. Colours help trace the circuits workings.
With regards to this should I take a length of wire run it underneath the matrix board, coiling it around component leads as necessary, and then solder ?
Old 24th August 2006, 08:31 AM   #12
R.I.P.
you will probably find under board is easier (just like tracks) but it depends on how busy it gets. Be flexible.
A 90degree bend is probably secure enough. Doing more (180degrees) makes it more difficult to make changes.
If the wire is very short just touching the side of a component leg will be enough to get a secure solder joint.
regards Andrew T.
Old 28th August 2006, 07:16 PM   #13
Is soldering components to LM3886 bad practice?
In the past I have tried soldering to IC's but have struggled to get good joints due to the IC package dissipating soldering iron heat.
Old 29th August 2006, 07:20 AM   #14
R.I.P.
Default CHIPamp works of art
I have seen some direct to pin build photos.
They look very effective and are often works of art that any builder would be pround of.
Try a slightly higher iron temperature. It will allow faster working and not put any more total heat into the pins.
regards Andrew T.
Old 29th August 2006, 03:22 PM   #15
Nordic is offline Nordic  South Africa
Nordic's Avatar
Some would say its the prefered way.... never had a problem soldering anything to a chipamp pin... not one of those stupid pins that is like oil and water whern you show it hot solder.
Old 29th August 2006, 05:21 PM   #16
...Make the ground pin long, and solder to a metal ground wire. I'm not exatly sure how to layout the grounding.
Decoupling:- As pin 8 is connected to V- through a resistor. Can pin 8 be used as V- decoupling point ? (Pin 8 is decoupled in the datasheet but so is the V- supply. Decoupling pin 7 to 8 would be much easier and looking at the -PSRR might be worthwhile.
Old 30th August 2006, 08:21 AM   #17
R.I.P.
correct grounding practice is crippled by the internal layout of most chipamps.
To help alleviate this inherent problem, the external grounding must be exemplary.
UNDERSTAND the requirement first, then design the layout to achieve the desired result.
Don't just blunder in and hope that big ground wires connecting every zeroVolt reference in random order will be successful.
regards Andrew T.
Old 30th August 2006, 11:53 AM   #18
Thanks for the tips.
Any grounding /pcb book recommendations ?
I suppose NS might supply the internals
Old 30th August 2006, 12:50 PM   #19
MellowTone is offline MellowTone  Australia
MellowTone's Avatar
Wouldn't it be the soldering irons wattage that would be the main factor here?
And I thought ICs were really sensitive to heat, on projects I have worked on in the past involving ICs, there have been warning about heat going into ICs and some have even requested little IC heatsink clamp thingies.
Cheers, Nic.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 30th August 2006, 05:14 PM   #20
R.I.P.
most semis specify 300degC for 10seconds maximum.
If you delay by trying to heat up a pin with too low a tip temperature then heat transfers to the internals and risks damage.
If you can get a succesfull joint at 330degC in 5 seconds you end up with LESS heat inside the semi and less risk of damage. But you must be quick.
regards Andrew T.
Self adhesive copper track GaincloneHide this!Advertise here!
Adhesive for ESL panel repair 405man Planars & Exotics 7 26th June 2014 07:24 PM
removing old adhesive for a refoaming ichiban Multi-Way 3 7th August 2008 01:49 AM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
pcb copper laminate glue adhesive gain wire Parts 6 12th February 2006 12:20 PM
Anybody knows where t oget cheapie self-adhesive copper tape?? li_gangyi Everything Else 8 13th December 2003 04:57 AM
