| Chip Amps Amplifiers based on integrated circuits |
For Gainclone application,is there really an audible difference between them???
#2 |
It depends on the amount of snake oil you rub on them
#3 |
It doesn't cost much to find out!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
its also a question that is applicable to chip amps vs discrete..
The schottky diodes are discrete, and have a very nice cut off characteristic, whereas the bridge's that are available tend to be encapsulated single wafer 'ordinary' diodes. However, and heres the rub - single wafer items are usually much, much better matched interms of the charecteristics in comparison to thier discrete counterparts - so in the gainclone, the psu behaves in a more uniform way with a bridge, compared to a discrete bridge made of schottkys. The downside is that most cheapo bridges have quite nasty sharp cut-off characteristics, and unless properly managed (in the power supply), can inject large amounts of RF into the circuitry bevause of it. This is often audible in a simple PSU, however it is so easily blocked using a high amperage choke (it only needs to be a few mH, and ferrite cores are ok in this instance) after the caps, on in each rail, and one in the ground connection, and then comparisons become in the main academic between the two types... Just my thoughts Owen |
#5 |
i just thought i'd say... stop stealing my name!
im the only owen in this village... just kidding.. i always wondered about what diod's to use for a rectifier.. but never really paid too much atention to it and always just used what i had lying around that was up to the job.. Owen |
#6 |
Its the surge current rating which is important, Schotty's tend to have a lower surge rating for a given nominal current. Its not just the switch on surge, the diodes only conduct for a short period of the sine wave see:
http://www.siteswithstyle.com/VoltSe...and_xfmrs.html which show it aint so simple! |
#7 |
If I can butt in without going too far OT, with silicon diodes/bridges, is "glass-passivated" of any concern when buying? My google skills fail on pros & cons re audio.
#8 |
DP,
I've been in this village for years, and other villages for longer - its just taken a while for another to join with the same name... ![]() Owen |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 4 rfb-02 rectifier bridge pcb's | BeerCan | Swap Meet | 1 | 23rd July 2008 07:07 PM |
| Rectifier Bridge on heatsink? | Killjoy99 | Solid State | 6 | 27th April 2005 03:38 PM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Bridge Rectifier | thylantyr | Solid State | 2 | 21st August 2003 09:11 PM |
| Page generated in 0.08778 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
