Old 18th August 2006, 03:21 AM   #1
neil_kaye's Avatar
Talking Integrated gainclone w/ NOS DAC and SB3
Well this started out a building a mono gainclone absed in Peter's boards. From there i purchased his NOS. Now i am thinking of housing the gainclone board, two transformers, NOS DAC and Squeezebox 3 (as the transport) in a single enclosure.
It is probably totally crazy but i would love the experts here to weigh in on the possibility of executing this project.
I have attached an image which is of a quick sketch mock up i did tonight. The thick bars separating the components would be aluminum bar stock to help contain EMF as well as, im the cas of the gain clone boards, act as heat sinks.
The transformers are 160 VA mounted back to back (vertically to save room).
Any suggestions ideas or cries of alarm would be greatly appreciated.
Old 18th August 2006, 08:28 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
It's a great idea to minimise the amount of interconnects and sockets but I would make one concession and that would be to keep the PSUs in one box and the rest of the system in another!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th August 2006, 08:37 AM   #3
dsavitsk's Avatar
The output impedence of the DAC is pretty high so you will need to choose a potentiometer and set the input impedence of the amp accordingly.
Old 18th August 2006, 10:29 AM   #4
Nuuk's Avatar
Or may be add a buffer.
Old 18th August 2006, 02:13 PM   #5
neil_kaye's Avatar
Nuuk / dsavitsk
Thanks for the feedback. What do you mean by input / output inpedence> I would definilty like to avoid using a pot so the questions arises about adding a buffer.... major newbie question here but waht is a buffer?
I was also thinking about the antenae for the squeezebox. What is the best way of dealing with that. Right now it appears that the metal "c" on the SB3 is the antenae although i have yet to open up the case... tamper proof screws and call.
I i still want to house the PSU in the case, and i assume you mean the amp psu's, althoug the squeezebox does have a small wallwar, what woud be the best way to do this?
And finally. I would naturally be using one AC input, what is the most effective way of splitting the AC power lines to each component once inside the case?
Cheers
Old 18th August 2006, 05:17 PM   #6
Nuuk's Avatar
Very little time to answer so may I refer you to the Gainclone section of my website.
Also some research on this forum will enlighten you further!
3.1 integrated possible? Brit01 Tubes / Valves 4 5th July 2008 05:34 PM
Integrated gainclone, NOSDAC and DAR neil_kaye Chip Amps 39 21st September 2007 07:36 PM
Integrated Amp toman_9 Solid State 0 22nd January 2006 12:36 PM
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
The ultimate integrated frugalphile gainclone yldouright Chip Amps 62 24th July 2005 11:51 AM
Page generated in 0.08938 seconds (74.55% PHP - 25.45% MySQL) with 11 queries
