| Chip Amps Amplifiers based on integrated circuits |
Can anyone suggest how to get rid of the Radio signal in inverted GC?
#2 |
usually reading the product documentation will help -- and Natinal Semi addressed this specific issue for all the Overture series chips -- a 200pF capacitor between the inverting and non-inverting inputs will do most of the job, but make sure to bypass the Vcc and Vee pins as indicated.
#3 |
I had this with my first GC. Trim every wire down to be the absolute shortest possible length. Move wire around so that you will have less disturbance, and the 200pF cap will also work, but should not be needed if your wiring is done properly. Do you have a picture so we can give more help?
Josh |
| Problem with hobbie FM Radio transmitter | bmattias | Everything Else | 4 | 19th August 2008 05:51 PM |
| radio problem | jeesus | Solid State | 1 | 1st August 2008 10:00 AM |
| Odd Amplifier/Radio Interference Problem | normalicy | Car Audio | 5 | 5th July 2008 05:59 AM |
| DC offset problem from noninverted GC | 5150ed | Chip Amps | 8 | 16th August 2006 04:39 PM |
| Sony MDX-C6500R radio problem | Bgt | Car Audio | 7 | 22nd July 2006 08:51 AM |
| Page generated in 0.07360 seconds (69.35% PHP - 30.65% MySQL) with 10 queries |
