| Chip Amps Amplifiers based on integrated circuits |
Hi there,
I'm preparing to start building a Gainclone style amp, and am considering the options for volume conrtol. As this stage I intend to use an Alpha pot until I gain experience. I will rig up a stepper motor to an extended shaft, with the pot mounted remotly from the front panel. My question is about remote volume control. I've seen plenty of kits around - that's not the issue. However, I wanted to control the remote volume through my existing Marantz remote (which has volume buttons for the electronic volume of the CD player headphone out). That is, I was hoping to use the single remote to control the CD and the volume of the amp. Can existing kits be adapted to be controlled by proprietary remotes? Cheers Stuey |
#2 |
I just recieved an email from someone willing to help me design a kit from www.chipamp.com (my first build) adding the LM1036 from www.national.com control, plus adding a remote control.
It's hard to get out of the recliner all the time, We are a remote society. I was informed the remote setup depends on what you want to control with the remote. I am just a student. I want more than a volume control, the new chips have THD+n about as good as it gets. I hope this helps. Here is the response I recieved: " I will provide more information later. I think it would be no problem to > provide a very simple remote controlled volume control with two microchip > controllers (one for the transmitter and one for the receiver). But first > you need to know what volume control chip you intend to use as this > affects the program. It's even possible to use a binary logarithmic > stepped volume control with precesion resistors and small relays, with a > remote control. The microchip controller then needs to output parallell > data for the relays. > > Balance control can be done digitally, by sending each volume control chip > or relay array a different code. Problem here is to keep volume setting > valid, so one channel volume has to increment, the other channel has to > decrement simultaneously. For correct multichannel volume control > front/rear and left/right, complicated attenuation schemes are necessary > involving floating point calculations > > I personally like the LM1971, it has the best sound quality so far. I > tried a lot of configurations and volume control chips. > > In a High-end preamplifier you don't want to use tone control, only volume > control with as low distortion and noise as possible. The LM1036 > distortion is way too high (0.03%) the LM1971 has 0.0008%." |
#3 |
Thanks, but I don't think you quite understood the question.
I'm definitely going to use a mechanical rotary pot, most probably with a kit based PCB for the receiver. I wanted to adapt one to accept commands from a particular proprietary remote. I'm assuming that they transmit on a particular frequency in the infra-red spectrum. What I wanted to know is how (if it's possible) you can adapt such a remote control kit, rather than using a universal remote controller. I most certainly only want volume control - source changes etc. are so infrequent it's not an issue. Cheers Stuey |
#4 | |
remote control. i myself had done a similar project but i used sony remote.. |
#5 |
i'm trying to do the same thing, but with a kenwood remoto (bad choice!!).
using a marantz remote won't be difficult i believe, for it uses RC5 (philips) protocol and most kits are configured for it.
old fashioned 3 way http://www.diyaudio.com/forums/showt...threadid=81723 small sub http://www.diyaudio.com/forums/showt...threadid=93185 |
#6 |
Thanks; I'll look around at RC5 protocal and see what I can come up with.
Stuey |
#7 |
#8 | |
I goofed that reply was from ec-designs@hccnet.nl email.
#9 |
I just hooked up a remote controlled pot that Brian from twisted Pear audio made up to my twisted pear chip amp. It uses a Sony protocol for a TV, I just programmed my existing remote to work with it. It is a MAJOR convenience. And highly recommended.
PJN |
#10 |
I get confused, Brian that I have communicated with is from
www.chipamp.com Twisted Pair. has nice stuff. rev C amp Could you share the infirmation please? What all does the remote do? Volume, on-off, balance? Iam looking for a way to connect LM1036 with a remote control to operate vol, balance, bass, treb, on-off to LM3886 amp. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 08:20 PM |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 09:22 AM |
| Remote volume control | poeee | Chip Amps | 3 | 30th December 2004 05:12 AM |
| Remote remote volume | simon dart | Parts | 3 | 7th November 2004 11:00 PM |
| Page generated in 0.12695 seconds (83.59% PHP - 16.41% MySQL) with 10 queries |
