Old 20th August 2006, 01:52 PM   #11
Hi
I reacently assembled a remote kit from Dantimax.
It uses the same code as some Philips televisions.So if your existing remote can control the Philips televisions as well,the changes are good.
My remotes from Sony DVD and Yamaha hometheater amp both are able to control the dantimax kit.They both have few buttons that can be programmed.
xxx I should correct my spelling xxx
Old 20th August 2006, 05:36 PM   #12
BrianDonegan's Avatar
I get confused,
Different Brian
I just hooked up a remote controlled pot
The one he is talking about uses a remote chip from Rentron (Microchip PIC with remote decoder code preprogrammed). It gives you an output for vol up/dn, channel up/dn, and digits 0-9, plus a toggling power output. I just used the Vol Up/Dn to drive an h-bridge chip from TI the controls a motorized pot.
You could easily use it to control multiple motorized pots, for volume, balance, bass, treble, etc.
Here's a link to the board I made. It's a really simple circuit (not much design involved).
Twisted Pear Audio
Old 20th August 2006, 06:45 PM   #13
ppcblaster's Avatar
Default THANK YOU
Thank You, I may have more questions.
One step at a time.
Thanks again
Old 21st August 2006, 04:00 AM   #14
Keeping it all very simple, you could even go with digipots for all the controls, have up/down buttons for each, and piggy back the remote outputs with them.
Maxim DS1804 pots have a simple up/down interface and they come in nice DIP-size packages. Cheaper than a motorized pot too.
EDIT: Actually, it only works on transitions, so you would need to set up an oscillator for each, still pretty simple. Not as easy as programming a PIC to do all the work, but...
Twisted Pear Audio
Old 22nd August 2006, 02:57 PM   #15
Stuey is offline Stuey  Australia
Hi Brian,
What's an 'H-bridge chip' if you don't mind me asking?
I've had other thoughts. I was thinking that I could use the existing Marantz CD remote (which has Volume up/down buttons for the headphone jack volume control). I figured there may be a chance that the 'system remote out' RCA socket could provide an output for volume when these buttons are pressed...or they MAY only work the volume via the volume control IC. Not sure.
But it'd be neat if I could drive a receiver in the amp via a simple RCA remote cord from the CD player system remote output.
Cheers
Stuey
Old 22nd August 2006, 03:10 PM   #16
An H-bridge is a circuit used to drive, among other things, a bidirectional motor.
Here's a link I found quickly: http://www.bobblick.com/techref/proj...e/hbridge.html
Here's the chip I used:
http://focus.ti.com/lit/ds/symlink/sn754410.pdf
It is a quad half h-bridge, enough to drive two motors.
Twisted Pear Audio
Old 26th August 2006, 12:44 AM   #17
Thanks Brian.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 09:22 AM
Remote volume control poeee Chip Amps 3 30th December 2004 05:12 AM
Remote remote volume simon dart Parts 3 7th November 2004 11:00 PM
Page generated in 0.08978 seconds (78.29% PHP - 21.71% MySQL) with 10 queries
