| Chip Amps Amplifiers based on integrated circuits |
Hello,
I found the following transformers avalable cheap for £5, however I dont know how many amps on each of the two taps the amps take? I can get a 2 x 100 va transformer at 18 volts ac or 2 x 20 volts ac at 6-7 amps. Which is best out fo those 2? What is really need to know is how many amps does a gain clone need? bare in mind I doubt I will drive it past 40 watts per channel. |
#2 |
I hardly know anything about Gainclones, but AFAIK, the amperage required depends on the load impedance. If you know it, I suspect you'd get better answers if you post the info.
For fun: The <20W 41hz Amp6 Tripath-based amp I'm building comes with a recommendation of 15V 50-100VAC transformers. [edit]The transformers you mention[/edit] might make sense for a 40W amp, based on my ignorant guesstimate. |
#3 |
I just put together another GC and three different power supplies to try out. First was a toroid 20V, 4A, second was another toroid 24V 5A and third was dual EI transformers 24V 5A.
Both higher powered trafos sounded better to me than the 20V 4A toroid. The dual EI setup won the day because it fit in the box I wanted to use for my PS! The difference in sound between that setup and the similar toroid was minimal at best and neither was "better". All that to basically say more available current seems to sound better to my ears.
--Sherman |
#4 |
hello,
thanks for your info, i forgot to mention i will be driving a 4 ohm load on each channel! it looks like that 20 volt one rectified to 30 is ideal then. However how much current will be needed for 4 ohm loads on each amp? |
#5 |
20Vac might just give you 29Vdc unloaded, falling to 26 to 27Vdc loaded. If you can source some enamelled wire you can add secondary windings to convert the transformer to 2*22Vac or even 2*24Vac. Scientific Wire Co. (SWC) are good suppliers.
regards Andrew T. |
#6 | |
I've built GC with as little as 120 VA and think they sound fine at low to medium volumes.
--Sherman |
#7 |
edited:
The 2x20V is much more powerful ? (2x20Vx6.5A=250VA) It should be twice the weight. The 18V 100VA may be slightly more suitable voltage for 4ohm eg with LM3886 (check the specs). But 100VA is marginal for 2x40W. At that price I would go dual mono (assuming you can buy 2 trafos the same). PS: If these are toroids and there are more available I'm sure other members would be keen to get hold of them. |
#8 |
You can download an Overture Design spreadsheet from NS that covers most "Gainclone" chips, and input your DC supply voltage, speaker impedance, etc. A warning will pop up if you exceed any safety margins. Very useful tool.
#9 |
Am I just slow in finally noticing the 2nd tab in that design guide where it shows a graph of power dissipation vs. output power? How long has this been there? Interesting. Not sure it is of much use to me .
-SL |
#10 |
Could be new? I've just got 'Calculations', 'Empty' & 'Empty2' tabs
![]() Yup, new to ver.1.5, I had 1.4
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| FS: Transformers | alexcd | Swap Meet | 0 | 19th November 2008 08:34 PM |
| WTB : Transformers | korben69 | Swap Meet | 1 | 27th June 2008 06:05 PM |
| my first amp (transformers???) | fitchmicah | Chip Amps | 5 | 7th January 2007 07:26 PM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| Page generated in 0.12967 seconds (82.07% PHP - 17.93% MySQL) with 10 queries |
