| Chip Amps Amplifiers based on integrated circuits |
Hei!
I desided to builed me the Lm4780 chipamp (dobbel mono). And now the question: Who's construction/designe is better, who sounds better (not inn therory), chipamp or audiosector? I know the the only difrents is the zobel, but I ask anyway Hilsen Jarre (sorry for the bad english) |
#2 | |
diyAudio Moderator Emeritus
The design is essentially the same. I haven't stocked the LM4780 boards for a long time on, and Peter should have them available for ordering now. Peter took the board for one more revision, adding the ability to run both channels seperately to allow for a stereo amp to be build from one chip. Best of luck on your project, -- Brian |
#3 |
i agree...
i used veteran's boards, excellent design and you'll spend very much less money than other kits... cheers! |
#4 |
Then the case is closed, it will be audiosetor.
A noter question, withs 10 000uF capasitors are recomended. Because the Panasonic FC does not go so high Jarre |
#5 | |
-- Brian |
#6 |
Thanks for the advice BrianGT!
But I have resacrted today and found Mundorf caps for amplifilers inn Norway. Do's someone have any expirens whit Mundorf caps for amplifilers? They are more exspensiv (Panasonic aroud 50 Nok (8,2 USD), Mundorf 130 Nok (21,3USD) for the 10 000uF), but I thout it will be more exspensiv. I think I will try them. Then I have too save some extra weeks Jarre |
#7 |
Sitting her and draing the amp on AutoCad. And I woundered how big (L and W) are the PCB.
Jarre |
| LM4780 SS Pcb | pinkmouse | Chip Amps | 67 | 31st January 2011 12:35 PM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| lm4780 p/s | j9184p | Power Supplies | 4 | 28th June 2006 05:18 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 09:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 07:13 AM |
| Page generated in 0.08770 seconds (73.40% PHP - 26.60% MySQL) with 10 queries |
