| Chip Amps Amplifiers based on integrated circuits |
I've seen such in hobby books, up to 120W. But never been able to find where to buy them.
They should be nice. I also question how their distortion figures will compare to the best that can be obtained by discrete components. I've looked, but does another thread deal with this?
#2 |
Did it Himself
I have a feeling you may have been looking at the old ILP modules. They were not chip amps at all, just basic discrete amps potted onto a heatsink. They ceased production over 10 years ago.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
One of the better known modules is the ILP type.
Check here: http://www.ilpelectronics.com/amplifiers/audio.asp They are sold by Farnell @ http://www.farnell.com/ ![]() Edit: Production still going on AFAIK.
UrSv Those who say it can't be done should not stop those who are doing it. |
#4 |
Richie, yes, ILP is what they were called.
So what is best to use today? |
#5 |
Did it Himself
Best? Read around and make your own mind up based on what you believe and complexity of the project and physical aspects. I'm not a fan of chip amps... Some love them...
#6 |
Here is the issue. I read about those ILP's in a book. They looked good because of the built in heat sinks. But I've never seen where I could buy them.
As far as chips, they usually are power tab, or dip. Of course dip doesn't do much for power. Power tab? I guess. I'm not sure which ones to go with. I don't know how they perform compared to the best discrete. Id prefere built in heat sinks. Maybe except for ILP, there is no such?
#7 |
Those ILP amps look great! Who made them, ILP Electronics?
I've never seen a good picture before. The pair of big capacitors is probably filtering for the fist and second stage, to give it good power supply ripple rejection? How well do they work? It seems like they could work as well as anything that could be made discrete? Not made any more? What does one use now?
#8 |
Did it Himself
ILP went bust about 10 years ago, somebody must have bought them out and started selling some of their traditional lines again.
The big caps are simply the PSU smoothing caps. You just need to connect a transformer. As to their performance, they used to be OK in their day and probably still are. As I said before it's open to debate if they are the ultimate thing to you or not.
#9 | |
http://www.ilpelectronics.com/sales/ilp_direct.asp The only chipamp I've come across with a built-in sink was the Sinclair Super IC12, from 1971. "Claimed to be capable of 6W RMS". |
#10 |
Since the ILP amps are basically discrete, seems like they could be as good as the best discretes??
Since they are made for mass market, they don't have as big a heat sinks as I would like to see. I think heat sinks are the biggest challenge for building your own high power amp. I'll read your links. |
| What might this mean for heat-sinks? | seventenths | Everything Else | 17 | 1st July 2008 07:20 PM |
| Heat Sinks | serengetiplains | Parts | 3 | 3rd January 2006 06:41 AM |
| Heat Sinks | 95Honda | Swap Meet | 14 | 7th October 2005 06:07 PM |
| Heat sinks - going the other way | jackinnj | Everything Else | 9 | 27th April 2003 05:01 PM |
| Page generated in 0.12974 seconds (66.00% PHP - 34.00% MySQL) with 11 queries |
