| Chip Amps Amplifiers based on integrated circuits |
Can anybody explain how to calculate the lowfrequency cutoff of input capasitor for inverted GC?
I commonly found the 4.7mf input cap for noninverted schematic but I already a pair of 1mf of very good cap, is the value is too low? |
#2 |
159155/(resistance * frequency)
#3 |
hmmmm..... I do not quite get it.
Do u mean? 159155/(resistance * frequency)= capasitor value |
#4 |
The low frequency cuttoff is 4Hz, so you can calculate the DC blocking capacitor by below formula
Ci = 1/(2*PI*f*Ri) If your input impedance is 22K Ohm Ci should be 2.2uF by the formula. |
#5 |
159155 = 1000000/(2*pi)
The formula unit is microfarad. |
#6 |
Thank a lot.
But what is PI??? |
#7 |
22/7
Greg Erskine |
#8 |
I tried both formulas or formuli. I got 1.80uf.
#9 | |
#10 | |
Technically it is the ratio of the circumference of a circle to its diameter. It is an 'irrational number', when the division is carried out it never ends and never repeats. For all practical purposes in these formulas just use 3.1416.
--Sherman |
| Frequency Cutoff | habsrock93 | Full Range | 2 | 21st August 2007 01:32 PM |
| Crossover cutoff frequency ? | Fradbut | Multi-Way | 3 | 22nd January 2007 09:31 AM |
| W Bin -vs- L 36 Low Frequency Cutoff | OMNIFEX | Multi-Way | 11 | 14th March 2003 07:15 AM |
| Reasonable low frequency cutoff | markkanof | Multi-Way | 5 | 12th June 2002 10:14 PM |
| Page generated in 0.09321 seconds (75.76% PHP - 24.24% MySQL) with 11 queries |
