Old 8th August 2006, 06:11 AM   #1
Default Good sounding CHEAP adapter for T amp?
Im looking for a cheap ($20-30US shipped) power supply for the Sonic Impact T-Amp that sounds about
as good as the original purpose-built power adapter,
or better (can't find the original adapter for sale). It needs to be "plug and go", and plug directly into the back of the amp, as I don't want to have to try to custom mod the power supply or anything like this. Also, I'm in Canada so it needs to run on 110/120v. I've seen people using 12v adapters that have anywhere from 1.5a - 5a. Is the amperage going to have an effect on the sound, or possibly, on whether the amp continues to work under load?
To that end, will THIS item work?:
http://cgi.ebay.com/LCD-MONITOR-AC-A...QQcmdZViewItem
Old 8th August 2006, 02:20 PM   #2
Default Re: Good sounding CHEAP adapter for T amp?
I can't see why not, as long as polarity is correct, /sreten.
Old 9th August 2006, 04:26 AM   #3
renfrow is offline renfrow  United States
renfrow's Avatar
Two avenues you might explore:
Radio Shack has a 1500ma adapter that I bought and it seems to do just fine. You pick the adapter that fits the connector on the T-Amp when you buy it. I don't remember which it was, however. I do remember that I got the wrong one and had to exchange it :-).
CB power supplies. These are 13.8v so will give you a little extra oomph. I will probably buy one of these for my next T-Amp.
Tom.
Now, we can do this the hard way, or... well, actually there's just the hard way.
-- Buffy Summers (Buffy the Vampire Slayer)
Old 9th August 2006, 04:32 AM   #4
13.8v to me, is asking for trouble with the SI-Tamp! I don't want to go over 12v, as these amps blow up very easily.
That said, I'm not sure what amperage is best? 1.5a or is there a risk if its greater, and is there an improvement if I get something with a higher amperage than the Radio Shack standard?
Also does the power adapter absolutely need to be regulated to ensure it doesn't go beyond 12v?
Old 9th August 2006, 07:12 AM   #5
preiter is offline preiter  United States
preiter's Avatar
Amperage shouldn't matter, so long as it's above the max the amp will draw.
That said, what is the recommended minimum current for a T-amp? I've heard 2A. Can you go lower than that?
Old 9th August 2006, 12:16 PM   #6
cpemma is offline cpemma  United Kingdom
I first used my T-amp (with 8R speakers) using a 12V 1.2A regulated adaptor, no problems at normal listening volume, the adaptor stayed fairly cool. And I doubt the standard AA cells the amp's designed to take can supply much current without massive voltage sag. But you can't have too big a house or too stiff a power supply.
Old 9th August 2006, 01:50 PM   #7
Sherman is offline Sherman  United States
I found a couple of 12V 2.5A adapters at American Science and Surplus for about $8 each. I think the website is www.sciplus.com but there is a retail outlet not too far from me that I found them at.
I've been using one with an SI amp and to be honest I can't hear the difference between it and running it on batteries. I don't profess to have golden ears and YMMV.
--Sherman
Old 9th August 2006, 03:40 PM   #8
preiter: The recommend min for the SI-T amp can't be 2A, since the Sonic Impact adapter is 1.5a
sherman: The closest thing I found to what you described on the American Science site is a 12v 2A, similar to the laptop/LCD power adapters I've been looking at recently (a box that has a seperate power cord that plugs into it). I don't know if they all are, but the one on the American Science site is a switching supply, and I heard this was not desirable for the SI-T amp.
cpemma: I've been having trouble finding a -regulated- adapter (with the proper female plug) suitable for the SI-T amp (ie. 12v 1.5a). Did you get yours online?
Old 9th August 2006, 04:13 PM   #9
sherman: The closest thing I found to what you described on the American Science site is a 12v 2A, similar to the laptop/LCD power adapters I've been looking at recently ...
Since AmSci is a surplus place their inventory changes. Sometimes they have lots of something other times they don't.
I think the adapter I have is a switching adapter as well but as I mentioned to my ears it sounds as good as running on batteries ,which in theory anyway should be best as you are getting "real" DC.
--Sherman
Old 9th August 2006, 05:17 PM   #10
Yes, but UK stores (Maplin and Rapid Electronics) who don't ship small orders abroad. Plugs can be bought separately if the as-supplied is wrong.
The switching type (SMPS) are excellent, that's what Sonic supply AFAIK.
No, batteries are "chemical" DC, all bubbly and no body, like keg beer.
need recommendation good sounding transistor tomat Solid State 6 8th July 2009 10:48 AM
Good/Bad Sounding Chips Wynand Chip Amps 12 15th July 2005 04:36 PM
Looking to build cheap, efficient, good sounding floorstanding speakers - the results tool49 Multi-Way 4 26th December 2003 08:43 PM
Looking to build cheap, efficient, good sounding floorstanding speakers tool49 Multi-Way 80 21st November 2003 03:04 AM
simple, cheap, great sounding tube amp? trespasser_guy Tubes / Valves 8 23rd December 2002 01:49 PM
Page generated in 0.12186 seconds (77.35% PHP - 22.65% MySQL) with 10 queries
