| Chip Amps Amplifiers based on integrated circuits |
A question about the input of amplifier designs.
Most amp circuits I see on this board have on the input: a parallel resistor to ground, a series capacitor and a series resistor in some configuration. The series capacitor is there to block DC. The parallel resistor, as I understand it, allows a small current to flow from the signal source, which some output stages require to work properly. I have never been able to figure out the purpose of the series resistor. Anyone care to enlighten me?
#2 | |
as far as i know : The parallel resistor stops high gain oscillation when you unplug the source. The Series resistors increases impedence a little bit and the series/parallel configeration as a whole creates a devider. the cap across the input stops rf getting into the input from cables etc the in series cap blocks dc.
mMmMmmMmmk? |
#3 |
there are commonly two filters on the input to an amp. A low pass and a high pass. The high pass usually comes first. series capacitor followed by cap to ground. The -3db frequency of this filter is F=1 / [ 2 Pi R C ] it is usually set between 1Hz and 10Hz. The low pass filter usually follows, it is a series resistor followed by a capacitor to ground. F-3 is usually set between 40kHz and 300kHz There is somtimes a resistor to ground from the input terminal to reference the input end of the capacitor to ground and help prevent a DC voltage building up on it if it is left unconnected. This resistor is usually about 10 times the input impedance of the amplifier.
regards Andrew T. |
| First design for a tube noob | lacrossebowe8 | Tubes / Valves | 3 | 4th January 2009 10:00 PM |
| PCB design for TDA1541 - noob needing tips | Painkiller | Digital Line Level | 0 | 3rd May 2008 10:06 AM |
| Help with 3way design, noob at home audio. | demon2091tb | Multi-Way | 5 | 3rd November 2006 08:59 PM |
| Speaker design, X-Over, and MTM Questions - Please help a noob! | sbolin | Multi-Way | 39 | 4th October 2004 05:14 PM |
| Noob - Needing help deciding what Gainclone design to use | tsnyder41 | Chip Amps | 5 | 19th May 2003 11:54 PM |
| Page generated in 0.09040 seconds (65.47% PHP - 34.53% MySQL) with 10 queries |
