Old 1st August 2006, 01:12 AM   #1
Default Attenuator step sizes in the usable listening range
Hi
Don’t know the best forum to post this in, but trying here first:
Deciding the steps in an attenuator, there is a trade-off between small steps eg 1 and 2 db; and less overall attenuation, esp for late night listening.
(note I will probably have 24 steps, so can make the steps below the listening range, quite large).
If you have used attenuators with 1/ 2 / 3 dB steps (I could well on commercial gear, but I don’t know what there steps are), in the * usable listening range * say 80 – 95 dB - what size step do you recommend?
Old 1st August 2006, 06:20 AM   #2
Francec is offline Francec  Australia
Banned
This may help;
http://homepages.tcp.co.uk/~nroberts/shunt.html
Old 1st August 2006, 07:27 AM   #3
you can increase step size above as well as below your normal listening range.
Go further, omit the steps above the loudest you will ever need.
Buy a cheap pot and wire it in temporarily.
Listen to some (a lot?) music at three levels you like.
normal , quiet & loud.
Measure the pot at each of these settings and use these settings as your guide for the stepped attenuator.
regards Andrew T.
Old 1st August 2006, 08:27 AM   #4
Thanks guys
Francec
If that reflects steps which are useful/ sufficient, it is suggesting
- a range of 21 db (steps 10 – 17) which are 3 dB,
- and a range of 14 db (Steps 17 – 24) with steps of 2 dB.
That sounds very reasonable.
Andrew
Yes, I will if it’s not in the usable listening range.
normal , quiet & loud . . .
I think you are right - that’s the best way to get it right.
I didn’t say that I am very tempted by www.promitheusaudio.com/tvc.htm
I need to try to “hold my horses” until I know exactly where (or how much) to steer ‘em . .
Cheers
24 Step Attenuator poynton Parts 1 9th January 2008 07:26 AM
23 step attenuator tryonziess Chip Amps 2 21st May 2007 12:33 PM
KT88 Usable range croccodillo Tubes / Valves 2 28th November 2006 07:24 PM
Series step attenuator Ipanema Solid State 14 17th November 2006 09:32 AM
12 step 10k attenuator problem vdi_nenna Everything Else 2 26th July 2005 07:10 PM
Page generated in 0.23162 seconds (30.32% PHP - 69.68% MySQL) with 10 queries
