PCB design of parallel of two inverted LM3886  with buffer and dc-servo.
Old 10th April 2012, 03:59 PM   #71
Roushon is offline Roushon  India
Default Volume control pot
It seems I am talking to myself. Finally found enough information and
availability of the motorized volume control in India.
But there is an issue I really need help: what value pot as volume
control should be the best?
The present stepped attenuator attached is 10K. But I feel when the volume
is raised high the sound becomes irritating. Does the volume control resistance
has some effect on the sound?
Please post a comment.
Thanks and regards
Roushon.
S. Roushon
Old 10th April 2012, 06:29 PM   #72
sangram is offline sangram  India
The pot loads the source.
Actually, the preceding stage sees the resistance of the pot parallelled with the input impedance. A 10k pot is advised when your source is capable of at least half that. A lot of sources do not like loads below 10k, so a 22k pot is kind of my minimum.
Lower impedances also result in lower current noise, so 22k is kind of my maximum as well.
Old 10th April 2012, 06:33 PM   #73
when the volume is raised high the sound becomes irritating
Could that be clipping. Not many "listeners" like clipped signals.
regards Andrew T.
Old 11th April 2012, 06:13 AM   #74
Default thanks
I knew someone will offer a helping hand. Thanks Sangram! I will look for a
22K pot.
Thanks Andrew for pointing out a possible reason.
The PS is quite heavy: +-35 volt and 5amp on each rail
and there are about 15000mfd cap on each rail. Channels
have their independent PS starting from toroidal. Do not
know if there is any other reason which can cause the
problem.
Roushon
S. Roushon
Old 11th April 2012, 12:17 PM   #75
Default ordered
Just ordered a 20K log motorized ALPS pot from RS component
India. I can use the same existing control unit to control
this pot I hope.
Roushon
S. Roushon
Old 19th October 2017, 07:37 PM   #76
asuslover is offline asuslover  Romania
Can u plz post the last schematic for your amp?
Thanks a lot!
PCB design of parallel of two inverted LM3886  with buffer and dc-servo.Hide this!Advertise here!
LM3886, XO, Buffer and Servo jackinnj Chip Amps 3 30th October 2008 01:14 AM
Non inverted, 3 x parallel LM3886 schematics and layout. markiemrboo Chip Amps 0 6th December 2007 01:42 PM
Copyright ©1999-2017 diyAudio
