PCB design of parallel of two inverted LM3886  with buffer and dc-servo.
Old 16th February 2010, 12:38 PM   #61
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Default Getting back some gain
Originally Posted by Roushon View Post
Finally checked after shifting the attenuator at the input of the buffer. No problem
now, the sound is excellent except for two minor issues:
1. Need to raise the volume almost halfway to make the amp audible, which
I do not mind much.
You're currently using the OPA627 as a unity gain follower. Its fairly easy to make up some of the lost gain (from snipping out the 100R in the T-network) by configuring this opamp to give you, for example, 20dB gain. Your attenuator circuit gives a maximum -6dB so at the very least it makes sense to run the OPA627 stage at +6dB to make up for that loss - I'd go for turning it into a X10 stage myself (18k feedback, 2k to ground).
If you want to keep the attenuator at the output of your OPA buffer, I think that's been the cause of your problem since it has an output impedance of 10k, and the input impedance of your LM3886 stage is only 1k. If you still have it between the OPA and the LM, it will only give you a gain of around 6dB from the power amp stage and plenty of instability as the 3886 doesn't like such low gains. So, instead of the 100R in the T-network, use a 1k in this position and your problem is solved.
Old 17th February 2010, 04:08 PM   #62
Roushon is offline Roushon  India
Default Thanks
Thanks a lot Abraxalito. I should have posted the attenuator circuit before,
then this situation would not have occured, I would have got the suggestion
of replacing 100R by 1K. I would not like to change the gain of
the buffer, also as I said I am reluctant to shift the attenuator at the
input of the buffer. So I will insert the t-network again by 1K and test the
circuit.
Roushon.
S. Roushon
Old 21st February 2010, 04:36 PM   #63
Default all is well
Replaced the t-network by 1K. Now both the channel are silent. Although
initially some noise was appearing in the faulty channel when volume was
raised and voltage also was flactuating. Needed to do lots of isolation
of diferent power cables and speaker wires from ground bass to get rid of this
noise. Now everything is perfect.
Thanks a lot for all the help.
Roushon
S. Roushon
Old 21st October 2010, 08:49 AM   #64
Default Do I need to ungrade the amp?
So far so good. I was playing the amp on my Open Baffle speaker. But recently noticed
a problem. I was playing a cd (Belafonte) which was recorded in some concert. So there
was in between clapping of the audience. The music played fantastic, but the clapping
becomes very loud and irritating, I need to reduce the volume. I know that the CD is
of very good quality and the recording also. Where is the problem? Is it the 1K
resistor in the t-network feedback? Is this resistor changing the frequency
response of the amp?
As such the amp is silent, I hear a faint hum/noise when I put my ear very close to the
speaker.
The amp diagram is attached again for convenience.
Thanks and regards
Roushon.
S. Roushon
Old 21st October 2010, 01:05 PM   #65
abraxalito's Avatar
You might be getting RFI-induced sibilance. I've encountered that on many of my chip-amp circuits. The first thing to check is the grounding for the input cable. If the screen of your input cable connects on to the PCB, that's probably the problem. In my experience, the solution is to run a ground cable alongside the input signal cable connecting the input ground terminal (presumably on an RCA-phono input connector) to the star earth. Disconnect the screen of the input cable at the PCB.
If this does indeed solve the sibilance on applause it will have other beneficial effects on the sound stage too.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 22nd October 2010, 06:17 AM   #66
Thanks Abraxalito.
This is probably correct, I do not remember. I was extremely careful regarding
grounding. I will open the amp and check again. Slight RF is there when power ON but
this completely disappears when volume raised and played for sometime.
I always remember your help when I was struggling with the amp beginning of this year.
Roushon.
S. Roushon
Old 10th March 2012, 06:03 AM   #67
Default So far so good...
Waking up this thread as I plan some modification in the
amplifier. So far I enjoyed the sound very much apart
from some minor issues.
Planing to open the amplifier in the coming summer
vacation if still I get some time then.
Firstly will see the RF issue. Just a two post and two years
back Abraxalito suspected that the screen of the input
cable is touching the pcb which is correct as I
see when studying through the pcb design and thought about
my wiring the amp in a clear mind.
Secondly I need a suggestion:
When I built this amp I did not have any speakers and
much knowledge about what I was doing. So built as
parallel of two inverted LM3886 design. Now that my
speakers (open baffle following Martin Kings design using
Eminence alpha 15a and Fostex FE103en) are 8Ohm
I see a parallel design is a waste. I would like to make
it a bridge. My first question is that is it worth taking
the trouble as I do not listen very loud music. I do not
know if making it bridge will have any effect on the
sound quality in medium to loud volume.
Finally there is a small problem with the attenuator
based volume control. The volume does not start from
zero. The attenuator circuit is attached in
post no. 59. Is there any solution to this problem?
Thanks and regards
Roushon
S. Roushon
Old 10th March 2012, 07:00 AM   #68
Default Attenuator
Forgot to mention that I truncated the attenuator circuit
to make it 64 step by removing the stage 10K + 6R31.
If that is the reason for the problem I can add two resistors
10K and 6R31 at the output of the attenuator. Extending
the whole thing by one more stage will need lots of hard work
as I will have to change the logic circuit also which is switching
the relays.
Roushon
S. Roushon
Old 12th March 2012, 05:26 PM   #69
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Hey..can anyone send me the gerber or .sch& .brd files ?
SivanandBalan
Old 6th April 2012, 07:56 AM   #70
Default opened!
Could not wait for the vacation. Just spent a day opening the amp and made
the following changes. Left it in its parallel form.
1. removed the 1 mfd input capacitors
2. moved the buffer in between the amp and the attenuator to avoid the
impedance mismatch
3. removed the 1K t-network resistors to move the gain down to 20. this
also solved the not-so-zero-volume start problem
4. solved the grounding problem: input cable screen sent directly to the
star ground
Now the advantages: zero RF, zero hum, sound seems to have more opened
up and filling the air in the room evenly.
But there is one problem with the attenuator which I am not able to solve.
When the volume moves from 15 to 16, 31 to 32, 47 to 48... there is a loud
TAK sound and when the volume is pulled down and crossed the above
stages. Do not know why...
Thinking of replacing the attenuator by traditional volume control. Any
suggestion regarding a very good quality dual 10K volume control will
be helpful..Also how does the motorized volume control work?
Thanks and regards
Roushon.
S. Roushon
PCB design of parallel of two inverted LM3886  with buffer and dc-servo.Hide this!Advertise here!
LM3886, XO, Buffer and Servo jackinnj Chip Amps 3 30th October 2008 01:14 AM
Non inverted, 3 x parallel LM3886 schematics and layout. markiemrboo Chip Amps 0 6th December 2007 01:42 PM
