Old 27th July 2006, 09:06 PM   #1
ash_dac is offline ash_dac  United Kingdom
Thumbs up Solderless gainlone amplifier? (crimps, wires and terminal blocks)
I was thinking of using crimp style connectors with wires, and terminal blocks to build a gainclone LM3875 amplifier. It would be a "fast build" .
What are the potential limitations ? contact resistance ?
Old 27th July 2006, 10:05 PM   #2
preiter is offline preiter  United States
preiter's Avatar
Well, you sort of need to solder the components to the PCB.
if you are talking about connections between the PCBs, toroid, jacks, etc. That will work fine. I did it in my gainclone to make it easy to remove/replace parts, reconfigure the wiring, etc.
Old 27th July 2006, 11:39 PM   #3
well, he may not be willing to use a PCB.
Old 27th July 2006, 11:43 PM   #4
Send a message via MSN to ELiTeHaYDeN
its hard to figure out what he means, it almost sounds like he wants to split the pins on the lm3875 and use connector blocks for the resistors etc
which i would not advise lol
mMmMmmMmmk?
Old 27th July 2006, 11:45 PM   #5
lgreen is offline lgreen  United States
lgreen's Avatar
Default do it!
Other than reliability and immunity to vibration I don't see why it wouldn't work, though it would be difficult to crimp to the chip pins. I say try it out, it would be fascinating to see a solder-free amp.
My DIY audio projects- PartTimeProjects.com.
Old 28th July 2006, 02:41 PM   #6
neutron7's Avatar
Check out this. it tells you how to make a el cheapo wire wrapping tool for almost free. wire wrapping is supposed to be better vibration resistant than solder.
http://www.toozy.com/wraphack/wraphack.html
Old 28th July 2006, 02:53 PM   #7
Useful if your Apollo Guidance Computer ( http://en.wikipedia.org/wiki/Wire_wrap ) shuts down
Thanks for the link.
Large terminal blocks for automotive SMPS? gmarsh Power Supplies 5 3rd March 2008 11:12 PM
Where to find Terminal Blocks? spooney Car Audio 4 6th November 2007 08:45 PM
car amp style terminal blocks kderedwolf Parts 1 8th October 2003 03:24 AM
terminal blocks cowanrg Parts 5 12th August 2003 11:32 PM
Using terminal blocks as Speaker connectors? Beggar Parts 4 27th July 2003 08:08 PM
Page generated in 0.09893 seconds (81.25% PHP - 18.75% MySQL) with 10 queries
