Old 27th July 2006, 04:14 PM   #1
Default lm4780 heatsinking...
hi all!i have to place heatsink on my lm4780 and i have 2 questions...how many °/W do you use?and how do you bond the chip to the heatsink?by screws? i don't want to crack it...isn't there another way?like a piece of metal on the chip where placing screws?
Old 27th July 2006, 04:15 PM   #2
BTW, i planned to use pentiumII heatsink with double fan about 0.5°/W
Old 27th July 2006, 07:46 PM   #3
Send a message via MSN to ELiTeHaYDeN
yeah screws, nylon screws if u dont want the heatsink to be live, and a pad for insulation, other than that just metal screws and thermal compound, a pentium2 cpu heatsink and fan would probebly be ok, but it will run quite hot at full power, pick up a old pentium4/amd heatsink and fan, that will cool it fine without any fan modifications, use a couple of zenors to lower the voltage perhaps if its too loud(the fan).
i gotta test out my little p2p copy of nationals reference pcb, ill be using a p4 cpu heatsink and fan, so ill let you know how it goes.
click here for image
mMmMmmMmmk?
Old 27th July 2006, 08:09 PM   #4
WOW!!i've spent so much money for the pcb... i never thought about this solution...
Old 27th July 2006, 08:27 PM   #5
lgreen is offline lgreen  United States
lgreen's Avatar
Yes, a piece of metal works fine. Here is an example from Sparky the chipamp. Using a fan with this provides sufficient cooling. If you are very careful and carefully position some TO-3 insulating pads, and use nonconductive thermal grease, the sinks should stay isolated.
My DIY audio projects- PartTimeProjects.com.
Old 27th July 2006, 08:41 PM   #6
thanx a lot, good idea but i think he uses screw and nuts but it's quite impossible to use nuts on pentium heatsink...
Old 27th July 2006, 11:37 PM   #7
the base on most computer heatsinks is thick enough to tap, and thread the bolts right into.
Old 28th July 2006, 03:24 AM   #8
well i didnt end up using the p4 heatsink/fan, i found something else laying about that was easier to mount too.
should give u a idea, at even midly turned up volumes(no fan), it hits SPiKe(nationals protection setup) very quickly, a 120mm fan kept it at bay however, it was mildy warm.
the heatsink is finned at the back, about 3cm in height, but this particular heatsink has a very thin base, which appears to be a bad thing, it majorily hotspots.
Click here for image
mMmMmmMmmk?
Old 28th July 2006, 06:57 AM   #9
yeah, sure that heatsink won't have less than 2°/w at first glance, and i think it's really not enough...better to try with p4 if you want to use it avoiding spike action...
Old 20th February 2007, 01:23 PM   #10
Niila is offline Niila  Finland
Send a message via MSN to Niila
Default Another question
Didnt want to make new topic for my questions.
Parallel, not bridged.
Would that be enough for two parallel lm4780's? I listen music at normal/quiet volumes and use +-34V rails.
Another question btw, can i use two 120VA transformers for these chips..one for each?
Cheers!
LM3886 Heatsinking englandinacan Chip Amps 6 14th April 2009 06:20 PM
heatsinking Ted205 Chip Amps 24 30th August 2008 08:50 AM
Class A heatsinking, or heatsinking in general! NUTTTR Solid State 27 22nd January 2005 01:48 PM
LM4780 Heatsinking jackinnj Chip Amps 3 5th January 2005 06:00 PM
Heatsinking has now become less dense! cunningham Solid State 5 9th November 2004 07:09 AM
Page generated in 0.10266 seconds (77.66% PHP - 22.34% MySQL) with 10 queries
