| Chip Amps Amplifiers based on integrated circuits |
Has any one built any kits using these chips and if so is it worth it, i.e what do they sound like ?
#2 | |
http://www.maplin.co.uk/Module.aspx?...ifier&doy=22m7 http://www.maplin.co.uk/Module.aspx?...ifier&doy=22m7 Why use darlingtons ? |
#3 |
You tell me ?
#4 |
Bought one of these maplin kits ,doesnt sound bad at all ,put some better caps on it Sover 4700 mf I had lying around and connected it up to a Skynet8080SMPS.Well worth investing £14.99 in .
#5 |
stickinsect. My kit has been gathering dust since I tried to connect a transformer (not Maplin or Velleman) and I kept blowing the fuse. How did you connect an SMPS to it ?
#6 |
Just connected the SMPS up +12,-12 and ground to the three inputs,(just use one of the ground connections on the board)the kit can be powered either with AC or DC in standard configuration.
#7 |
it sound pretty nearly perfect ! in small volume ¡£
| Darlington pair | Tualek53 | Parts | 9 | 16th August 2005 07:54 AM |
| Darlington and Triple darlington | lumanauw | Solid State | 78 | 1st December 2004 12:57 AM |
| What is a darlington output exactly? | mjarve | Solid State | 4 | 18th July 2004 01:28 AM |
| Epitaxial Transistor | lubbie | Parts | 2 | 28th August 2003 07:50 AM |
| Page generated in 0.13604 seconds (51.89% PHP - 48.11% MySQL) with 11 queries |
