Old 13th July 2006, 07:34 PM   #1
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
Default LM4780 Bridged Mono (136 watts of pure energy! ;-) )
Double sided PCBs for diying.
Bottom:
Old 13th July 2006, 07:35 PM   #2
DJ Exprice's Avatar
Top:
Old 13th July 2006, 07:56 PM   #3
Do you have a few for sale?
Old 13th July 2006, 08:53 PM   #4
DJ Exprice's Avatar
Not yet, but I might have some made.
I will post more files soon.
Old 13th July 2006, 09:27 PM   #5
DJ Exprice's Avatar
Zipped Hi-Res Images
Old 13th July 2006, 09:30 PM   #6
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Has anyone done a Gainclone PCB using surface mount parts? It seems you'd be able to tidy up the layout quite a bit as well as make it more compact. Not that it really needs to be, but why not if it's possible.
Brian
Old 13th July 2006, 10:02 PM   #7
I'm about to do one, full SMT ;-) except of course the things that don't exist as SMTs.
I'm stuck between parallel or bridged or parallel/bridged, i'm trying to make up my mind what will be best to drive either 6 or 8 ohms speakers. Also designing PCB for PSU with regulation, when i'm done i'll publish everything here.
Old 13th July 2006, 10:18 PM   #8
DJ Exprice's Avatar
Please bridge it
I am starting to use surface mount parts. The reason this one did not use surface mount parts is because I used the same schematic file as the person who created the original schematic (moamps) and board (single sided). It had no smd/smt parts. :P Good design though!
Old 14th July 2006, 12:52 PM   #9
BWRX, well P-A's QRP02 has some SMD.
http://home5.swipnet.se/~w-50674/hif...0_overview.jpg
Old 14th July 2006, 04:02 PM   #10
DJ Exprice's Avatar
Eagle File:
Bridged LM4780 Amp jackinnj Chip Amps 17 24th March 2011 04:36 AM
Lm4780 Bridged PCB Baracus Chip Amps 8 7th January 2006 12:45 AM
+-25volts = ??Watts bridged?? SkinnyBoy Solid State 37 27th March 2003 12:22 AM
Page generated in 0.11174 seconds (74.57% PHP - 25.43% MySQL) with 11 queries
