Old 12th July 2006, 09:10 PM   #1
Default BPA-200 Pridge/Parallel Amp
Hey guys,
So far i've been amazed with the knowledge in here!.
I was reading the BAP200 document from national and seems like a very interesting design for the ones tha don't actually know what will be the final impedance of the speakers.
A couple of questions though
1.Has anyone built that design? If so, how good is the performance?
2.Is the servos good or bad? improvement in audio quality & improvement in safety and dissipation issues or degradetion of audio quality however improvement in safety and dissipation?
3. On this document (last pages) the rails are displied as +-42 volts which is the max of the IC? Can this be right ? Recommended from the manufacturer? I really don't get it.
Based on my calcs for a mid design for 6ohms speakers max rail is 30V.
4. Will this (exact) design work well on the LM4780? I'm asking since i the 4780 has better SNR and i have already 10 of them :-).
Has anyone built this with 4780s?
Thanks a lot.
Old 12th July 2006, 09:27 PM   #2
Default Re: BPA-200 Pridge/Parallel Amp
Originally posted by otherside
Hey guys,
Ive built it,it sound good
Hey guys
I did not use servos. I used the inverted mode and zeroed out the dc offset with a potentiometer on the + signal input
Hey guys
That is the unloaded voltage, with the chips connected the voltage will drop a few volts.
Hey guys
It should work.
I never tried it but I think someone on this forum did. Search this forum there is plenty on the bridged parallel lm3886(4780)
Old 13th July 2006, 05:59 PM   #3
jaudio thanks for the reply,
anyone else who used the servo circuit, or the LM4780?
Old 13th July 2006, 07:07 PM   #4
Default BPA 200
Servo's can poorly impact the sonic signature of the chips. There are many better ways to eliminate DC.
Old 13th July 2006, 07:42 PM   #5
For example?
Old 14th July 2006, 01:42 PM   #6
Using the drv134 ?
I'm looking into this also, I want to build 2 BPa200 monoblocks. I've got 4x brianGT 4780 kits already.
Old 14th July 2006, 06:17 PM   #7
After some research and after reading about 100 pages in this forum i think that the DRV134 is the way to go...
Already ordered some ;-)
Old 17th July 2006, 03:28 AM   #8
troystg is offline troystg  United States
troystg's Avatar
digi01 (Zang) made and sold a few BPA 200 boards. I have yet to assemble mine but the layout and PCB's were outstanding.
He is VERY good with sharing. He "MAY" just give you the files to have some made. Would save you lots of time and they were debugged for you.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 22nd July 2006, 03:27 PM   #9
gxlz is offline gxlz  China
Default Will do AMp with lm3886 bridged-paralleled
Someone on the forums had build ,sound is very good.I will build it useing 6Xlm3886 on each channel.
Old 24th July 2006, 10:25 AM   #10
veteran is offline veteran  Poland
veteran's Avatar
I'm thinking about such amplifier but using 6xLM3875 chips. It's a simple way to make good sounding and powerful amplifier with all protection circuits.
Simple audio solutions
blog.unisonus.com
PSU Parallel Help SkippyDogg Power Supplies 8 11th November 2008 07:05 PM
PSU Parallel Help SkippyDogg Everything Else 0 1st November 2008 05:01 AM
parallel sub skyraider Multi-Way 1 28th December 2005 08:12 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Page generated in 0.10544 seconds (80.57% PHP - 19.43% MySQL) with 11 queries
