I would like to build a circuit using an lm4780 in bridged mode using only a +24V supply(two 12V batteries). Does anyone happen to have a schematic handy? The data sheet shows how to build a single supply, and how to build a bridged, not not a combination of both.
Ringo
Ringo
I'm not sure if you can do it on fashion of the single supply example on the datasheet, really don't know.
One way is to use a boost SMPS to get it up to 48 then split it, having said that i have no idea what effect that will have on an audio amp, i've used it for other applications a lot of times.
You can get up to 93% efficiency. The actual circuit is quite simple.
