| Chip Amps Amplifiers based on integrated circuits |
Can anyone suggest schematic of preamp or buffer with gain more than 10X and matched with inverted GC?
#2 |
Here is a simple opamp buffer with a gain of 11.
or at least it would be if the file would upload!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
Ho thank u so much Nuuk.
Can you tell me which chip # is used in this schematic ? Is the step place before or after the buffer? Can I use my 100K step? |
#4 |
Depends if you use single or dual opamps. I suggest goig for singles. Try OPA134 to start with.
Put your buffer after your 100K pot.
#5 |
100K Pot
555 I can save big bug now. Anyway, what should be the +- voltage for this opamp??? and how can I design the PSU of it? |
#6 |
A suitable PSU is shown on Decibel Dungeon. See the DD Project pre-amp and the GC buffer and pre-amp pages.
#7 |
Hmmmm..... Can I use OPA627AP or AD797AN instate of DRV134PA???
#8 |
You should use your pot/attenautor instead of the 51 k resistor in the schematic. You don't want that resistor to load down the pot.
AD797 is probably a bad idea for line level circuits. It is specially designed for low-level low-noise applications, and has some internal design choices that might not be so good for high input levels. |
#9 |
Who mentioned DRV134PA?
What you need to do is RESEARCH! There is a lot of information available and a lot to learn. You can't build good hi-fi just by asking questions - it isn't that easy! Look at datasheets. You can find out what voltages are involved. Look at other people's circuits and see what they use. Get something simple up and running frst - then start to tweak with exotic components.
#10 |
Thank u Nuuk and Christer.
I shut my mouth for a while .
| PCB design of parallel of two inverted LM3886 with buffer and dc-servo. | Roushon | Chip Amps | 74 | 11th April 2012 11:17 AM |
| Look for tube buffer for inverted LM3875 | Mrpong | Chip Amps | 7 | 26th July 2006 08:18 AM |
| noob question: inverted/non-inverted | dieselpower | Chip Amps | 2 | 20th December 2004 09:19 PM |
| Circuit questions - Inverted vs non-inverted (again) | alvinlim | Chip Amps | 4 | 1st July 2003 11:27 AM |
| Page generated in 0.10249 seconds (74.62% PHP - 25.38% MySQL) with 11 queries |
