Old 10th July 2006, 01:11 PM   #1
5150ed is offline 5150ed  Thailand
Default Input transformer for Inverted GC
I want more gain from my inverted GC but I do not want to add buffer or tube buffer, want to keep it as pure and simple as I can.
So is 1:4 input transformer works for my inverted GC, if yes what is the input Impedance work for the application?
Old 10th July 2006, 01:28 PM   #2
analog_sa's Avatar
Bad idea. The reflected input impedance is likely to overload the source. What's wrong with the chip providing gain?
As much as i like transformers they seldom provide voltage gain for free.
Old 10th July 2006, 01:40 PM   #3
Dear Analog- Sa
I am using OPA541AM ship and having problem with it gain.
Firstly, I used common inverted GC schematic which have 22X gain and I got problem with high frequency distortion.
So I reduce the gain to 12X and very satisfy with its sound but not its gain coz I use it with step as passive volume.
I want to reduce the gain to 10X and adding one input stage but still want to keep it passive.
Any suggestion?
Old 10th July 2006, 03:12 PM   #4
analog_sa's Avatar
The high frequency distortion is probably intermittent oscillation.
What might help:
- PS bypassing on the chip pins
- output Zobel
- small resistor in series with output
- a better grounding scheme
Old 10th July 2006, 04:46 PM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Or changing the speaker cables.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th July 2006, 03:32 AM   #6
Can you explain more on these term?
- output Zobel
Old 11th July 2006, 03:55 AM   #7
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Small 33pf to 100pf between +ve and -ve inputs...
Zobel:Rc network 2.2ohms/2watts and 100Kpf across the output
SivanandBalan
Old 11th July 2006, 09:18 AM   #8
analog_sa's Avatar
That certainly isn't PS bypassing on the chip pins...
100Kpf
You mean 100KuuF, right?
Inverted Interstage Transformer NickC Tubes / Valves 4 5th January 2011 11:57 PM
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
noob question: inverted/non-inverted dieselpower Chip Amps 2 20th December 2004 09:19 PM
Mic input transformer udip Solid State 4 15th November 2004 01:02 AM
Circuit questions - Inverted vs non-inverted (again) alvinlim Chip Amps 4 1st July 2003 11:27 AM
Page generated in 0.09742 seconds (73.14% PHP - 26.86% MySQL) with 10 queries
