Old 9th July 2006, 07:34 PM   #1
luvdunhill's Avatar
Default Chipamp'ed Computer Speakers
Hi all, I'm looking to build a pair of "powered speakers", similar to standard computer speakers. My speakers will be 8 ohms and I need about 8W power per channel. I need a dual mono design, as I want to place each mono amp inside of the speaker enclosure, with the heatsink integrated into the back panel. My current box design provides for a 4" x 8" usable space on the back panel. Also, I'd like to power each speaker with it's own wall wart. Are there any designs that will lend themself to this application?
Is it possible to adapt the PCBs available at www.chipamp.com to be powered by a wall-wart?
Someone else suggested modifing a Sonic Impact T-amp, which sounds like a good idea, but I'd really like to go with the dual mono design, so I'm not sure if this would work.
Thanks!
-Marc
Old 9th July 2006, 08:07 PM   #2
phn is offline phn  Sweden
phn's Avatar
Even simpler design.
Edit: The SI is ideal for the job and one I would consider.
Old 9th July 2006, 08:07 PM   #3
Default Re: Chipamp'ed Computer Speakers
Thanks!
-Marc
Use two of them. One in each speaker enclosure.
Old 9th July 2006, 10:35 PM   #4
luvdunhill's Avatar
another idea:
http://home.eunet.cz/rysanek/pdf/tda2003.pdf
Old 10th July 2006, 04:53 PM   #5
Send a message via MSN to DoomPixie
if you used two sonic impact T-Amps you could also have one in each speaker and Bi-Amp the speakers! so say on the right hand speaker you would have one channel of the amp running the tweeter and one running the woofer.
Owen
Old 10th July 2006, 07:09 PM   #6
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
I'm making an amp thats a 24w stereo bridged amp.
Gerber Files:
Old 10th July 2006, 07:12 PM   #7
DJ Exprice's Avatar
Eagle File:
Old 10th July 2006, 07:14 PM   #8
DJ Exprice's Avatar
Gerber File "Rendered" Post Script Files:
Old 12th July 2006, 07:14 PM   #9
ash_dac is offline ash_dac  United Kingdom
how's that td2007a amp' going ?
Tda2005 has similar internals.
td2005 kit here : http://www.electronic-kits-and-proje.../3000/3143.pdf
Old 13th July 2006, 07:20 PM   #10
destroyer X's Avatar
Default Take a look at TDA8510J, this one is used by Creative Labs and sounds nice
It has 4 amplifiers inside..you can assemble two of them in bridge mode and this will produce more than 12 watts rms with 0.004% of distortion...something near the audibility..almost nothing of distortion...many others, using 12 volts, only produce this power with big distortions alike 10 percent that is the same as reproduce music in one crashed speaker filled with small stones to shake.
The other two amplifiers can be used for left and rigth speakers with wonderfull 4 watts undistorted each one...and flat response.
this is used as a 2.1 speaker system, having a subwoofer of large compliance and an input filter made using an operational amplifier...something alike 4558 or zilions of others.
It may fit your needs...i have one and i feel good to listen it....the power is not more and not less than needed, and distortion is small in normal levels of audition.
regards,
Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee
Computer Speakers inrank Full Range 1 19th July 2006 10:07 AM
Chipamp for computer - which one ?(need about 4W X 2) ash_dac Chip Amps 9 7th June 2006 07:00 PM
5.1 Surround Sound for Computer - ChipAmp DSchmidt Chip Amps 0 24th December 2005 05:22 PM
Simple/Cheap computer speaker chipamp Mr Teal Chip Amps 4 9th May 2005 10:32 PM
What computer speakers you ppl use? downhere Multi-Way 16 30th October 2001 10:48 PM
Page generated in 0.13008 seconds (69.09% PHP - 30.91% MySQL) with 11 queries
