| Chip Amps Amplifiers based on integrated circuits |
What would happen if I remove R3 and .1mf cap and connect pin 7 to ground directly?
Is there any harm? |
#2 |
hi 5150ed,
I've made a few IGC, and all have NI input connected directly to ground. So I wouldn't expect you to have any significant problems. I believe R3 is an attempt to reduce DC offset, I could be wrong. Why don't you try both and see what happens? regards
Greg Erskine |
#3 |
yes, there are some microAmps flowing out of the opamps input pins --
that design uses unusually large resistance -- about 1/4 the magnitude would be better. |
#4 |
Yes, the input bias currents are flowing through the two balanced 220k resistors (the 10k on the inv input isn't there for DC) so unbalancing by deleting the one 220k will surely give gross DC output offset.
Cutting down the values on the 220k and 10k series R would be much better, also from a noise standpoint, but that would lower the Zin and you would need a lower vol control than 100k. This is a major problem in inverting apps and also the reason why most would avoid it. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#5 |
Thank you so much.
But I am very new here. Can you Janneman can you explain in easier words? I should keep 10K and reduce 220K to how many K? Is this also reduce gain of my amp? [I am so confused. I am using OPA541AP chip, some said I should keep the gain at only 10, some said between 10 to 20 is ok. Do u have any idea?] I only have 100K step, can I adjust it to 50K by parallel 100K resistor with the step output? |
#6 |
If you are new to all this, make things simple for yourself. Don't try to modifiy circuits that you come across with different chips!
Have a look at the circuits on my web site. There is a very basic IGC there and a fairly comprehensive FAQ section.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#7 |
Thank Nuuk.
Can you give me your web site's address? |
#8 |
Click on the www at the bottom of my posts.
#9 | |
#10 |
There is a button with www on it. In the same place there is a button with email on it at the bottom of your post!
| Inverted GainClone's gain question? | 5150ed | Chip Amps | 15 | 10th July 2006 08:12 AM |
| My first non-inverted gainclone circuit | eranrund | Chip Amps | 21 | 19th June 2005 07:24 AM |
| noob question: inverted/non-inverted | dieselpower | Chip Amps | 2 | 20th December 2004 09:19 PM |
| PCB for Inverted Gainclone | 2Bak | Chip Amps | 8 | 19th February 2004 09:09 AM |
| Non-inverted Gainclone | jpask | Chip Amps | 1 | 29th March 2003 08:01 AM |
| Page generated in 0.10395 seconds (74.50% PHP - 25.50% MySQL) with 11 queries |
