beginner want to make device...
Old 6th July 2006, 05:20 PM   #1
evo1622 is offline evo1622  Hong Kong
Default beginner want to make device...
* First of all , I am sorry about that my english is too bad , hope you can understand what I say >< *
Hello~ I am a student , I am on hoilday now...
I want to make a audio device during my hoilday ...
however , I don't have any PCB or instruction
Do you have any PCB which is suitable for beginner ?
Old 6th July 2006, 05:32 PM   #2
DJ Exprice is offline DJ Exprice  United States
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice
You might want to try making an LM3886 Amp.
They're easy to make, and very nice sounding.
I recommend either buying a www.chipamp.com kit or, if you are an extreme DIY-er, use Russ White's PCB layout: http://www.diyaudio.com/forums/showt...642&highlight=
I still need to finnish my first one I started to build!
Old 6th July 2006, 05:51 PM   #3
ahrsix is offline ahrsix  United Kingdom
Smile PCB
Hello evo1622, and welcome to the site. You need to say what sort of circuit or PCB you want, you say audio, but do you want to make a simple doorbell or a stereo amplifier? I wish you luck and I hope you find what you want. Your English is very good I have tried to learn a different language but I could not do it, well done.
ahrsix
arrsix
Old 6th July 2006, 06:18 PM   #4
I am sorry about that I didn't say what kind of audio I want to make ~
I want to make a amplifier
thank you for your help
Old 6th July 2006, 06:52 PM   #5
Default PCB
Hello again, what power do you want ?
arrsix
Old 6th July 2006, 10:44 PM   #6
davidlzimmer is offline davidlzimmer  United States
Either BrianGT
Or Peter Daneil
offer fine kits at a great price.
Poor stereo mix? Switch to mono! Perfect.
Old 7th July 2006, 07:05 AM   #7
I don't have any idea in power of amplifier , that amplifier is for study
this is my first time to build an amplifier
Do you have any suggestion?
Furthermore......
Is PCB possibly made by me?
I bought some PCB etchant .
Can I draw a circuit on copper borad , then use the etchant to etch it?
Old 7th July 2006, 07:14 PM   #8
DoomPixie is offline DoomPixie  Wales
Send a message via MSN to DoomPixie
I might aswell point out that there are chipamp circuits out there that are simple enough not to need a PCB.
One i built a while back for instance, sounds ok, enough power to drive pretty much anything, uses cheap and readily available parts, and best of all its simple! http://www.oselectronics.com/downloa...554Q_CNV_2.pdf
I used the schematic in the datasheet for a stereo amplifier but changed the input caps for 1uF cap's anything between 1uF and 10uF works well as input caps on this amp.. there is a noticable difference useing lower values than this..
I havent tried anything above 10uF. i tried 10uF non polar electros but liked the sound these 1uF polypropelyne caps give better so i am sticking with them.. it is nice and simple and deffinatley dosnt need a PCB..
Runs quite happily on a little 12V SLA battery or i am useing a small 100VA toroid which is giving me about 18V after rectifier and a single 4700uF filter cap bypased with another 1uF cap and it is perfectly happy running from that aswell..
Hope this is of some help,
Owen
Old 7th July 2006, 07:28 PM   #9
If you are TRULY a beginner and wanting education more than a disired result try HERE
They offer all kinds of kits, many which run from a battery.
Old 8th July 2006, 06:12 PM   #10
DJ Exprice's Avatar
Sure, a battery could be used, but if you think you can be careful with AC primaries and secondaries, I say go ahead and try a transformer with a bridge rectifier and some smoothing capacitors.
Just wire that up like it says on www.chipamp.com 's website - the snubberized power supply.
AC to DC: AC Transformer secondaries to Bridge rectifier to Smoothing capacitors to DC
beginner want to make device...Hide this!Advertise here!
how to make wireless turn on device audioholik Parts 3 29th July 2009 01:59 AM
ESL AMT device... moray james Planars & Exotics 8 16th January 2007 02:45 AM
Does this device make sense for speaker design andy2 Multi-Way 12 10th February 2005 06:39 PM
