| Chip Amps Amplifiers based on integrated circuits |
I just finished my inverted gainclone using OPA541AP, 16V-0-16V 5A tran and 100K TKD step. The sound is really impressive.
But I wondering I have to turn on the step around 1.00-3.00 o'clock to get the same loundness as 9.00-11.00 o'clock from my other int'amp. Is there anything wrong? [ I normally found gainclone with step is enough gain for int' amp] My amp is truely humless, even connected to my 97db isophon fullrange. I measured DC at my bidingpost around .4 and .5 mV. And voltage +- 24V after diod. Any suggestion ???
#2 |
If you have followed the spec sheets then you will have set a much lower gain for your OPA541 GC than for a GC using one of the LM chips. I expect that's why you find you have lower volume levels.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
I use R1=10K, R2 and R3 = 220K.
Should I adjust anything? |
#4 |
I'm not sure what R1, R2 and R3 refer to but it looks like you have set the gain to around 22. This is too high for the OPA541 and you should reduce it to around 10!
#5 |
Hmmmm....... You mean that I have to adjusted R2 adn R3 to 100K? And the gain will be much lower
. What should I do to keep to raise the gain ??? Do I need preamp??? |
#6 |
Yes, if you need more gain then you will need a pre-amp with some gain. How about a valve pre? I tried one with my OPA541 GC and the combination was excellent!
#7 |
Ho in fact my chip is OPA541AM not AP. Is there anything difference?
Do u got schematic of ur tube pre amp? Anyway, thank u so much |
#8 |
No it doesn't matter which version of the OPA541 that you use, the gain should be kept to around a maximum of 10.
Details of my preamp can be found here and some 'simpler' (but very good) preamps can be found here .
#9 |
the opa541 is built to work. it has an excellent "phase margin" and is stable at any gain. but its gain-bandwidth product is low. basically, that term is just as you would expect: gain*bandwidth = GBP. high gains mean low bandwidth.
the lm chips have a high GBP, but are not unconditionally stable, and require a gain around 10 to function. as for the low volume, i can't tell for sure, but maybe you have something wrong on the current limiting feature of the opa541.
if only it could be used for good, not evil... |
#10 |
Thank u so much Nuuk, but i still can not see the picture
.Do u have the schematic for inverted OPA541 with 10X gain? |
| Optimum gain for Inverted OPA-541 AP | 100db | Chip Amps | 6 | 27th July 2006 11:35 AM |
| Inverted GainClone question? | 5150ed | Chip Amps | 35 | 10th July 2006 08:16 AM |
| Basic Inverted Gain Clone | caw | Chip Amps | 3 | 8th June 2005 06:51 AM |
| noob question: inverted/non-inverted | dieselpower | Chip Amps | 2 | 20th December 2004 09:19 PM |
| Inverted gain clone power amp only? | tubenut | Chip Amps | 1 | 26th March 2004 08:28 AM |
| Page generated in 0.14560 seconds (72.92% PHP - 27.08% MySQL) with 10 queries |
