| Chip Amps Amplifiers based on integrated circuits |
Well, after several months collecting dust on my dresser, the purchase of a adire kit61 two-way inspired me to complete my GC. I am still not quite finished and have to add the volume control, input selector and power switch (as well as the front panel!).
However, I hooked it up last night and wow! not a trace of noise, even when turned up to 10! A pic: |
#2 |
Nice job! The burn in process is a very pleasant experience. Enjoy!
Poor stereo mix? Switch to mono! Perfect. |
#3 |
Nice job,
I will posting pics too. Post your case when you get the panels finished! Dominick
A real amateur enthusiast! |
#4 |
upon further review, i am having a problem
![]() I am using a 300VA transformer and the 30V seems to push it a little hot (right channel starts cutting in and out after some time at higher volumes), so i am going to need to rethink my heat-sinking. I wonder - if i drill some holes in the copper bar if that would give it enough surface area, or should i somehow try to attach a sink... Byron |
#5 |
I would say fix the copper bar to the bottom plate with thermal paste as the easiest way to increase your heatsinking.
It may be enough. |
#6 |
ha! For some reason i never thought of that! Thanks...that's a great idea.
Byron |
#7 |
oh oh...now i have a more serious problem.
I took the copper bar off of the standoffs and attached it directly to the chassis, but now i am getting a strange noise from one of the channels (and the other is not doing anything) when i power up the amp and connect my preamp... it's like a long "zip" tone, and then it starts going "zip, zip, zip" - zip is my best approximation of the noise it makes (the actual chip makes this noise...it is reflected in the speaker as well if they are connected) any ideas? from the instructions on the chipamp site it looked as if the chassis ground could be used for both the mains ground as well as the amp. board ground, but other places in this forum say that this is not the case...does it seems as though i have a ground loop problem? or something else? Should i not attach the bar with screws? Any help would be appreciated! thanks, Byron |
#8 |
anyone have any suggestions or ideas?
Byron |
#9 |
Do you have insulators between the chip amp and the copper plate? Or, do your chips have built in insulation?
#10 |
the chips are the LM3886 from national - i believe they are insulated...
Byron |
| One more DIY TT is born | livemusic | Analogue Source | 18 | 20th December 2005 09:44 AM |
| New Aleph30 born | mpopovics | Pass Labs | 4 | 15th July 2005 06:47 AM |
| new gain is born | sith | Chip Amps | 9 | 4th October 2004 06:27 AM |
| New DAC born | mdlover | Digital Source | 8 | 10th July 2003 09:20 AM |
| A new Aleph3 is born... | Smithers | Pass Labs | 9 | 10th January 2003 01:41 PM |
| Page generated in 0.21957 seconds (42.88% PHP - 57.12% MySQL) with 11 queries |
