| Chip Amps Amplifiers based on integrated circuits |
I have aquired an amplifier with one working chanel, and one channel that seems to stick to one power supply rail (DC voltage). It uses an STK461 chip amp and the number and structure of the components inside looks relatively simple. Whilst i can aquire a replacement chip i am wondering what other tests i should run or common faults to look for before i go buying a chip that i don't need. Any pointers or links to tutorials etc?
#2 |
There's very little externally to go wrong with these chips. The only thing I can think of is to check that the DC isn't coming from a preamp stage (eg a missing rail to one of the opamps). This is unlikely though.
It is likely the chip is damaged possibly due to a short on the channel. Replacing the chip is the most likely fix. |
#3 |
Maybe you need this.
#4 |
The chip is damaged,I have had simmilar experiences with STK series IC's ~ STK 459 and 4141 ,these chips are very sensitive to shorts in the output.But I doubt if you will be able to obtain a genuine STK 461 as these became obsolete arnd 10 years back...
#5 |
The chip you're looking for is available at http://pacificsemi.com/search.php for $6.00 each.
Just an advice, when you install those kind of chip, place an alligator clip with a wire at each pin ,hook up to the ground .Just move the clip from pin to pin when you touch the pin with the iron.These are very sentitive to static. |
#6 | |
Watch out for counterfeit STKs by the way folks ![]() James |
#7 |
my supplier says they sell STK461, I will buy a replacement chip, remove the old one and see how i go. The old one has lots of pins, is the best way to remove it to snip the pins at the base then remove, then pull the pins out individually?
#8 |
Ya, cut those with wire cutter, will be a lot easier,but again, be careful with the iron when you touch the pins from the new IC, ground those pins
#9 |
What is the best way to ground the pins? Run an alligator clip to somewhere (where), or do i just keep them all connected (so no voltage between the pins)? Sorry for being a tad ignorant.
#10 |
Just connect to case or body of the amp
| System Troubleshoot: Need Help | ronfi | Analogue Source | 2 | 17th October 2008 10:07 PM |
| Help me troubleshoot this design, please | teemuk | Solid State | 19 | 7th August 2006 10:07 PM |
| Technics SL-J90 troubleshoot | Samson | Analogue Source | 1 | 30th December 2004 09:53 AM |
| My P68 sub amp just went poof - help me fix/troubleshoot it! | Jonathan M | Solid State | 21 | 23rd December 2002 07:08 PM |
| Help - Troubleshoot | arkay | Tubes / Valves | 16 | 5th January 2002 05:53 AM |
| Page generated in 0.12148 seconds (64.51% PHP - 35.49% MySQL) with 11 queries |
