Old 1st July 2006, 01:27 PM   #1
viki is offline viki  Portugal
Default Connecting AMP IC (TDA8560) to car radio speaker out
Hi, I am planning to built the amplifier in anex, but I want to connect it to the car-radio speaker out.
The problem is that the negative input of the TDA8560 is ground comun(only by a 4,7R resistor)
The question is if the pin 2 of the TDA8560 must be connected to the power ground, in all shemmatics i see it is connected to power ground , including the data-sheet, but that is not convenient for connecting the speaker out from the car-radio
So if i connect the radio speaker out to a voltage divider than connect to the inputs of the IC pin 2 and 1, disconnecting the pin 2 from power ground will it work fine?
Tanks for any help
Connecting headphones to guitar amp speaker output mike6182 Instruments and Amps 6 21st November 2007 10:20 AM
Oscillation (?) upon connecting speaker richie00boy Solid State 14 10th October 2006 07:00 PM
Car amp with TDA8560 carlodg Chip Amps 1 24th August 2005 07:43 PM
Connecting a speaker to a headphone jack Gambit Multi-Way 1 22nd August 2004 06:56 AM
tda8560 PCB Alex Mir Chip Amps 0 27th March 2004 09:05 PM
Page generated in 0.06457 seconds (60.73% PHP - 39.27% MySQL) with 11 queries
