Old 30th June 2006, 01:58 PM   #1
sancte is offline sancte  Argentina
Lightbulb LM4781 power supply
Hi everybody, i'm designing a project with 2 LM4781, +-25 V, that means 6 independent channels of 25~30W.
What about the power supply?The datasheet does not specify anything about the input current per channel.
Thanks in advance.
Santiago.
Old 30th June 2006, 04:42 PM   #2
Depends on if you want that 25-30W per channel to be possible with all 6 channels driving full power at the same time. Then you would need enough current for about 2A per channel or 12A. But it all depends on what you want and how much you want to spend on the power supply. You can also do something like 2 power supplies and have the channels that require the most power on different supplies since some channels, like rear surround channels aren't quite as demanding. But then you need to be sure your GND'ing is all well done. As long as you use a good star GND and don't create loops you shouldn't have any 60Hz hum.
-SL
Old 1st July 2006, 01:09 AM   #3
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
You always want to have a little left-over amperage too. Use my Bleeder Resistor Switch or just a normal bleeder resistor. If it's a normal bleeder resistor, make sure it's not too low in ohms and not too high .
Lm4781 Pcb venki Chip Amps 32 9th December 2008 11:27 AM
LM4781 and LM3886 Alphas Chip Amps 2 5th March 2005 08:43 PM
I can't make PCB's: 1/2 p2p LM4781 Beggar Chip Amps 11 19th August 2004 08:05 PM
Anyone know where to get a LM4781 or LM4782 in the UK? Beggar Parts 6 6th July 2004 06:43 PM
Page generated in 0.10216 seconds (54.83% PHP - 45.17% MySQL) with 10 queries
