Old 26th June 2006, 08:09 AM   #1
pwan is offline pwan  United Kingdom
Default Carlos's Low value res config with 3875
The original Carlos's proposal on the low value res config (2K / 100 Ohm for feedback res) is to LM3886. I wonder if anyone ever try this with LM3875 (whose current output is much lower than 3886 in Carlos's design) ?
Thanks.
Old 26th June 2006, 08:32 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you have different resistor values you will also get different properties like noise and output offset. To me this seems to be a bit below optimum.
/Per-Anders (my first name) or P-A as my friends call me
Old 26th June 2006, 09:37 AM   #3
sangram is offline sangram  India
I tried with 4766 and it worked fine (4.7K/220). DC-offset is very low (less than 5mV per channel).
I don't like the sound, but it could be any number of things. I suspect it's the chip that doesn't sound good, but I'm going to experiment with different values and then with different resistors before I blame the chip, the resistors, or the values.
Just FYI, I liked the LM4780 best when connected with high value resistors (220K/10K) but in that case even the resistors used were different and the offset was too high. I don't believe in resistor sound too much, but knowing the horrible components we get in our country, I'm not ruling anything out...
Old 26th June 2006, 11:30 AM   #4
frank1 is offline frank1  United Kingdom
How about measuring the performance so you can quantify "doesn't sound good"?
The PC sound card is a very powerful tool for audio testing. There are some very good audio spectrum analyser tools available (free). Some even contain a tone generator.
Personally, I use TrueRTA (there is a free but limited version) for testing my amps.
What's audible should also be measurable!
Frank
Old 26th June 2006, 11:54 AM   #5
Perander,
What do you mean "To me this seems to be a bit below optimum."?
PS: Thanks frank, sangram.
Old 26th June 2006, 12:23 PM   #6
analog_sa's Avatar
Maybe that noise will be too low
Old 26th June 2006, 12:27 PM   #7
Frank
I agree. I actually have a full suite of test tools downloaded some time ago, including a distortion analyser, tone generator, etc. My recording software has a spectrum analyser built in as well, and I have Speaker workshop as well which works well.
Never got around to using any of it though...
Maybe I'm just lazy!!!
Edit: I think what P-A was saying is that the resistor values need to be higher than 2.2K/100 ohm. I guess I agree.
Old 27th June 2006, 11:34 AM   #8
OK I will try it soon.
Thanks all for your comments.
Carlos! This is my amp thanh Solid State 11 9th August 2005 04:07 AM
Carlos grounding Scheme kestrel200 Chip Amps 17 20th May 2005 11:20 PM
Carlos regulated PS pcb antomas Chip Amps 0 18th May 2005 03:21 PM
PA100 or Carlos Improved NIC sith Chip Amps 0 10th May 2005 07:58 PM
Page generated in 0.45006 seconds (19.72% PHP - 80.28% MySQL) with 10 queries
