Old 25th June 2006, 12:54 PM   #1
ozonek is offline ozonek  China
Question Is LM4732 simplified version of LM4780?
I just wonder if LM4732 from NS is the simplified version of LM4780?
I ask this because I know in the IC industry, it is common practice to bin the raw material after test according to the performance of each unit. I wonder LM4732 and LM4780 have the same die and the only difference is LM4732 just has some defective circuitry/ transistor but it still can work.
Old 26th June 2006, 02:51 PM   #2
folks, any idea?
Old 26th June 2006, 02:52 PM   #3
pinkmouse's Avatar
I suspect that this is a question you need to direct to National's tech support.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th June 2006, 02:54 PM   #4
lgreen is offline lgreen  United States
lgreen's Avatar
In other words, it just might be.
My DIY audio projects- PartTimeProjects.com.
Old 27th June 2006, 11:21 AM   #5
glennb is online now glennb  Australia
Default Re: Is LM4732 simplified version of LM4780?
Given that the LM4732 has the same pinout as the LM4780 (implying the internal chip layout is similar, being two LMP3886AT silicon dice), and the specs are almost identical except for the output power, these is a good chance the LM4732 is just a LM4780 which failed the LM4780 test specs.
I compare LM4780, 3886, 3875, 1875 on my web pages at
http://home.pacific.net.au/~gnb/audio/lmcomp.html
Glenn.
Old 27th June 2006, 01:20 PM   #6
What's more, LM4732 (2x50W) is slightly more expensive than LM4780 (2x60W)
Old 27th June 2006, 09:16 PM   #7
RDV is offline RDV  United States
Perhaps two 3875s?
RDV
Old 28th June 2006, 06:56 AM   #8
ir is offline ir  New Zealand
Send a message via ICQ to ir
the 4732 was released several months prior to the 4780. i know this for certain as i when i sampled a couple of 4732's they were the highest power output devices National offered.
that would got to say then that the 4732 is not a simplfied 4780 or 4780 reject. well, not initially at least.
Old 28th June 2006, 09:19 AM   #9
I also highly suspect that LM4732 is 2xLM3875.
Improved/simplified X-100???? Circlomanen Pass Labs 26 20th April 2007 03:20 PM
Simplified FLH's? leadbelly Full Range 8 7th February 2006 08:53 AM
My version of LM4780 Lamicz Chip Amps 3 30th October 2005 11:41 AM
Simplified LM3886 amp with PCB KostasTheGreat Chip Amps 39 21st November 2004 07:26 PM
Page generated in 0.13247 seconds (59.12% PHP - 40.88% MySQL) with 10 queries
