| Chip Amps Amplifiers based on integrated circuits |
Is hot glue conductive? I mean is it at all??? I wouldnt think so, but I mounted an led using is and it os smeared across both the neg and pos terminal. It was fine at first and then began blinking after a few hours of use. Now, it is totally dead.
Is there a small conductivity in the glue that slowly killed it? Thanks, Dominick
A real amateur enthusiast! |
#2 |
No it is not, well maybe in the 50 mega ohm range, not enough to ever effect an LED.
Check your voltage and current sounds like to much voltage. |
#3 |
Speakerholic
Why not try a test? Put a blob on something you know to be non-conductive, let it cool and measure with your probes at specific distances
#4 |
Good idea--Ill do it although my meter is not very sensitive!
Dominick
#5 |
Run of the mill hot glue is LDPE, Low Density PolyEthylene. That is an excellent insulating plastic. Really excellent as in good for many kV DC per mm.
Your problem might be just from running too much current through the LED, or perhaps the heat it received while the hot glue was applied and setting got to it. I doubt that though.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
| What glue to use | feverdog873 | Multi-Way | 17 | 6th January 2009 12:46 AM |
| Gel glue | loninappleton | Full Range | 18 | 29th December 2007 02:03 AM |
| Thermal Conductivity of Kapton Compared To Aluminum? | kelticwizard | Everything Else | 7 | 20th June 2007 06:23 AM |
| crossover conductivity problem | REALFLEO | Parts | 16 | 3rd January 2007 06:15 AM |
| help with Thermal Impdeance vs. Thermal Conductivity | Eric | Pass Labs | 4 | 22nd July 2005 08:23 PM |
| Page generated in 0.07450 seconds (71.34% PHP - 28.66% MySQL) with 10 queries |
