Old 17th June 2006, 10:00 PM   #1
ah_fu is offline ah_fu  Singapore
Send a message via AIM to ah_fu Send a message via MSN to ah_fu Send a message via Yahoo to ah_fu
Default adding DAC to gainclone
hi,
anyone here has try adding a DAC to a gainclone?
Old 17th June 2006, 10:15 PM   #2
What do you mean exactly?
Old 18th June 2006, 04:02 PM   #3
the gainclone is a power amp....
so i am thinking is there anyone out there that has a DAC circuit that will reprocess the signal before going in to the gainclone...
of course, the DAC portion is in the same chassis as the gainclone....
seems like a DAC would be better off on a CD player.....
Old 18th June 2006, 05:04 PM   #4
nuteronix's Avatar
Default CONVERTOR D-A
Not sure what your going for, but have your pic they're all CONVERTOR D-A :
MC1408P8
DAC0800LCN
DAC0800LCx
DAC0808
DAC0832LCN
M151-017
DAC08CP
TDA1545
CS4390-KP
DAC08EP
DAC0830LCN
Just refer to the datasheets for more info
Old 18th June 2006, 09:23 PM   #5
raromachine's Avatar
It seems to me that you just want to house a DAC in the same chassis as a Gainclone? Some sort of selfcontained poweramp and DAC in one.
I was planning to do this with a DIY USB DAC for a friend.
Old 18th June 2006, 10:26 PM   #6
Hi
Just buy and build this USB DAC ...is complete, the buffered output is enough to drive the gainclone. Input is only USB, though (no SPDIF).
And so there are many, many more possibilites.
Erik
Old 19th June 2006, 06:09 AM   #7
Originally posted by ErikdeBest
...USB DAC ...is complete, the buffered output is enough to drive the gainclone. Input is only USB, though (no SPDIF)...
Wooooooooooooooooo! Look at the price on that sucker!
I bought and built the AW-d3 from these guys (none in stock atm): http://www.audioworkshop.com.hk/index_en.htm
And I've yet to find the sound unacceptable - its definately better than my laptop's output
Old 19th June 2006, 07:12 AM   #8
http://www.6moons.com/audioreviews/w...th2/brick.html
check this out.... USB TO RCA ....
this sure can be a good additional feature added to a gainclone...
what u guys think about this hybrid integrated amp?
Dared MP5 , read a few good reviews on this amp....
pretty interesting to know what power amps is inside....
http://www.soundscapeav.com/dared/dared1.htm
Old 19th June 2006, 08:21 AM   #9
with this USB1543 DAC added on... the only input source is through USB.
how do we still separate the original inputs on the gainclones such that we have the options to use only the gainclones or the DAC?
Old 19th June 2006, 11:55 PM   #10
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
Just cheat it and use an iMic
Adding an amp GlennDrodge Solid State 2 13th August 2009 05:16 AM
adding aux's bodaddy Instruments and Amps 10 22nd May 2008 05:40 PM
adding second HDD to PC AndrewT Everything Else 80 5th December 2007 01:38 PM
Adding IR to a gainclone? AJ Bertelson Chip Amps 1 23rd December 2003 02:36 PM
Adding LED to gainclone damitamit Chip Amps 11 6th September 2003 09:34 PM
Page generated in 0.13676 seconds (66.39% PHP - 33.61% MySQL) with 10 queries
