| Chip Amps Amplifiers based on integrated circuits |
I would like to try to build some sort of stepup amp to amplify my phono cartridge going into an MM phono stage. Essentially do an opamp stepup stage.....if possible. My cartridge is a Denon 103R with .28mV output. I would assume someone has explored this already but I haven't found info. Is it possible to do this lowlevel cartridge output justice? Thanks for any info you can provide.
Tom |
#2 |
#3 |
a better solution to a head amp might be the single fet as shown in
The Analogue Addicts Phono Preamplifier 2006 Edition |
#4 |
You will have no problem using step-up transformers with your DL-103. The Altec 4722 should do. It's common and relatively cheap. I believe it has a ratio of 1:18. Step-up transformers go hand-in-hand with the DL-103 and Ortofon SPU.
You might have to parallel a 10k resistor to match the load. |
#5 | |
Previously: Kuei Yang Wang
Konnichiwa,
An affordable transformer that works well enough with a 103 is the Amplimo TM3. Others have mentioned the "single gemstone headamp", which originiating the japano-french envoironment of Kaneta, l'Audiophile and co is seriously good. Here a version redrawn as stand alone pure headamp.... This is as build this time, you can increase the values of all PSU capacitors as large as the space you have and you can get them, mains transformer needs to be off-board, current consumption is around 30mA. You could also try just a set of 10 Rechargable NIMH Cells, if you get the 2100mAH AA cells you should get 11 days constant non stop play from a single full charge. In that case the batteries replace the PSU from the 7812 onwards. Sayonara |
#6 |
Doh! Just ignore my first reply.
Kuei Yang Wang, sweet design. I'm not into fets, but I could learn to like this. |
#7 | |
Konnichiwa,
Variations of this theme where my MC Stepups for a long time. I only found one MC Stepup transformer I really liked before the custom designed (and ultra expensive) S&B TX-103, an ancient grampian console Amp pull (quite similar to the Altecs you mention, but mo bigga an betta). Given that the 2SK170 from Shuro costs 58 Euro Cents and the rest of the parts even at high quality cost very little it is a worthwhile little device for stepup. Sayonara |
#8 |
Very nice. How much gain does it?
#9 | |
Konnichiwa Stereo San,
If you give 4V/kOhm more supply voltage the gain scales lineary with the drain load. You can think of the J-Fet as a trasconductance cell with (due to the 68R source resistor) around 10mV/V transconductance.... So if you up the pre-regulator to a 7818 and the main regulator to a 7815 you can increase the Drain load from 1K to 1K8 and get around 25db stepup. The next round up would be 7824 (and more AC) & 7818 as regulators and 2K7 Drain load for nearly 30cb stepup. Ein remains all the time around 2nV|/Hz due to the added circuit resistances. BTB, in my case this is part of a complete Phonostage, which is pretty traditional, but non the worse, sonically, for it: http://www.diyaudio.com/forums/showt...394#post942394 Sayonara PS, I noticed the OPA1632 via your website. I'll be cooking something with it soon.... |
#10 |
Thanks Kuei, that looks perfect. I think I'll try to prototype one and check it out.
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| Phono preamp modding (opamps and capacitors) | JWFokker | Analogue Source | 4 | 19th March 2007 10:20 PM |
| 2-stage DHT: high-mu vs. interstage stepup | Rocky | Tubes / Valves | 17 | 15th February 2006 11:02 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Upgrading opamps in I/V stage | 5th element | Solid State | 7 | 10th February 2004 09:53 PM |
| Page generated in 0.13631 seconds (67.13% PHP - 32.87% MySQL) with 11 queries |
