Old 15th June 2006, 06:52 PM   #1
Default How do I look up info on specific chips?
I happened upon an old amp-pack from a Blaujunkt car CD player (actually it was built by the same factory that built CD players for Sony). This particular model had a detatchable amp-pack to facilitate a shallower mounting depth (the amp-pack could then be mounted remotely like any seperate amp).
I forgot I had this, since it was barried in a "parts" drawer. I cracked it open and found these two chips:
TDA1519A
20989
HSH9114 2
I was wondering if anyone here knew of a source for looking up these chips. I think I remember that the info on the face plate of the head unit suggested 30watts X 4, but I know thats prolly based on 14.4v @ 20% distortion (guessing).
I was just wanting to get an accurate picture of this amp before I did anything with it.
(insert clever anecdote here)
Old 15th June 2006, 06:58 PM   #2
pinkmouse's Avatar
Google is your friend!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th June 2006, 08:23 PM   #3
Yep, though I did do a pretty extensive search on google this morning before I posted here, I just googled the actually TDA# and it took me right to the source...painfully simple.
Thanx,
3LB
Old 15th June 2006, 08:56 PM   #4
Default FWIW: specs
The specs say: Class B operation/ 22w BTL (I assume that's bridged)/11w X 2 stereo @ 14v with 10% THD into 2 ohms (6w with 10% THD into 4ohms/ 4w @ .5 THD) Power consumption is 25w.
There are two chips on the board with a switch that selects 2 or 4 speakers mode but I remember that the speakers wire needed to be wired differently as well.
I think I'll run a search on the actual board itself...
I guess I'm wondering if both chips can be bridged together...
Best Digital Filter Chips and Info? fastcat95 Digital Line Level 19 28th April 2011 10:16 AM
Looking for a specific cap... viction Parts 1 10th August 2009 06:59 PM
Question about different gnd's on a specific amp Ermac Solid State 12 14th July 2009 07:43 AM
Need help getting info on Class H+ chips DonoMan Chip Amps 4 20th October 2005 08:11 PM
Finding Info on Older Chips The Shaman Chip Amps 4 18th February 2005 10:02 PM
Page generated in 0.26363 seconds (24.01% PHP - 75.99% MySQL) with 10 queries
