| Chip Amps Amplifiers based on integrated circuits |
#11 |
woldn't that only work for single ended PSU ?
#12 |
Unless I'm wrong, should work just fine...
The switch connections used when turned off to drain caps would be connected to the V+ & V- thus when switched off V- would be the 'new' ground (ground is relative after all). |
| switch-on, switch-off sequence for preamp/amp | cbutterworth | Tubes / Valves | 1 | 2nd March 2007 12:41 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Main on/off switch for amp using a piezo switch | using_e | Solid State | 13 | 20th June 2006 05:55 PM |
| Switch box | scarr3d | Parts | 1 | 26th October 2003 07:57 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.16369 seconds (32.39% PHP - 67.61% MySQL) with 10 queries |
