Old 14th June 2006, 06:32 PM   #1
Default Hot glue on wood case for mounting?
I am trying to mount LED's onto the sides of my cedar wood case and was wondering if someone knew a good trick for it.
I am planning on using a hot glue gun! Will that stick adequatly over time??
Thanks,
Dominick
A real amateur enthusiast!
Old 14th June 2006, 07:20 PM   #2
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
This actually doesn't sound like a bad idea . It would probably work really well.
Old 14th June 2006, 07:56 PM   #3
Default Re: Hot glue on wood case for mounting?
Thanks,
Dominick
That's typically what I do, especially on plastic cases, I've seen plenty of commercial equipment do the same. If you use a big enough wad of glue it will never come off. Something that you can do is sink a couple of staples or nails with the heads raised above the surface just next to where the led will be. When you apply the hot glue use enough to flow around the nailhead. That will lock the hardened glue in place, in case it doesn't adhere well to the wood.
G.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 14th June 2006, 08:10 PM   #4
Thats a great idea.
Thanks,
Dominick
Old 14th June 2006, 08:14 PM   #5
reever is offline reever  United States
reever's Avatar
Silicone (sp) works very well also. We have used it here at work for years.
Also any RTV (Gasket making stuff) from Auto parts store will work too.
Old 14th June 2006, 09:59 PM   #6
frank1 is offline frank1  United Kingdom
Seconded, silicone sealer works great and is easily removed.
Frank
Old 14th June 2006, 10:12 PM   #7
lndm is offline lndm  Australia
Hot melt glue has stuck so well to my wooden frame, it once took a sliver of wood when I removed it. It sinks into the grain.
Though LED's don't get hot, I have carelessly used hot melt glue on components that get hot , you can imagine what happened
Undoing wood glue...advice needed :( Glowbug Full Range 10 23rd December 2007 03:11 PM
for a wood chassis, is glue enough? riotubes Parts 3 6th October 2006 04:25 PM
Best way to glue wood without clamps? mr_push_pull Multi-Way 40 11th October 2004 06:21 AM
Wood case for amp. dhenryp Chip Amps 5 3rd August 2003 03:52 PM
Calling Veneer Experts: Iron and Wood Glue Milzie Multi-Way 20 26th December 2002 01:09 PM
Page generated in 0.17016 seconds (45.69% PHP - 54.31% MySQL) with 10 queries
