Old 22nd June 2006, 11:35 AM   #11
Russ White's Avatar
Send a message via Yahoo to Russ White
Hi Max,
It will not be long now, but I am still doing some experimenting with another version of this circuit that I think (well actually know, as I am listening to it now!) will be very, very, cooool
Look for a new thread soon...
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 25th June 2006, 01:13 AM   #12
cjd is offline cjd  United States
Geeze Russ... do you slow down? Can you lend me some of your project/play time?!
Do me a favor and continue using a "basic" circuit around the chips themselves, and I will be able to try your variants very quickly indeed (once I source parts) since I went the modular approach... Yet another reason to have done that!
C
Old 26th June 2006, 03:27 AM   #13
Russ,
I really like the simple elegance of your circuit. My only concern is the imput impedance. 2.2k seems awfully low to me. Has that been a problem? Do you know what the power out is into 8 ohms?
Old 26th June 2006, 11:33 AM   #14
Russ White's Avatar
Carl,
Yes the input impedance is 2.2K, and no it has not been an issue for me, but I am using a preamp which can easily drive a load down to say 500ohms or so. I am using my Twisted Sibling preamp. I also have it DC coupled since I know there is no DC on my source.
Alternately you could simply take a good opamp such as the AD8620 and use it as an instrumentation amp in front of the THS4131. That will get you very high input impedance.
You can read about Twisted Sibling here:
Twisted Sibling - THS4131 based preamp/buffer/SE-BAL converter
Cheers!
Russ
Old 26th June 2006, 08:26 PM   #15
Russ,
Have you thought about what it would take to double up on the LM3886's to double the power output?
Old 26th June 2006, 08:29 PM   #16
Russ White's Avatar
Originally posted by Carl_Huff
Russ,
Carl,
Stay tuned. I have thought it through extensively. I have something I will post soon. For now you may enjoy reading this:
http://www.diyaudio.com/forums/showt...344#post940344
That should do 100-150W into 8ohms without any problem.
Cheers!
Russ
Old 27th June 2006, 12:01 AM   #17
It won't like my speakers though. 2.9ohm nominal.
C
Old 27th June 2006, 12:04 AM   #18
Russ White's Avatar
Which one?
The 4702 circuit I linked to a couple posts ago would handle that without a blink.
Old 27th June 2006, 12:09 AM   #19
Default Super symmetry?
Am I missing something?? this looks like a balanced line driver circuit , you know a "A typical bridged amp" not super symmetrical looks to have a common feedback loop to the LM and the THS/OPA? if not please explain how it works???
Old 27th June 2006, 12:14 AM   #20
Russ White's Avatar
Default Re: Super symmetry?
TI Licenced Nelson's Super Symmetry patent in there design of the THS4131. By nesting the feedback of the output stage with the fully differential input stage I gain all the benefits of the Super Symmetry.
Search the forums for more info on Super Symmetry. It is pretty cool stuff.
The results so far have been very very pleasing.
Cheers!
Russ
FS: Twisted Pear TXO-2 Overture Amp Paul Ebert Swap Meet 2 12th May 2009 04:08 PM
FS: National Overture Class-D Demo Board Amp speaker Swap Meet 3 24th March 2009 03:05 PM
Overture for sale Peter Menting Swap Meet 1 21st June 2008 12:14 PM
Unprotected Overture Design Guide 1.4 scgibson81 Chip Amps 1 23rd June 2004 05:13 PM
Copyright ©1999-2013 diyAudio
