| Chip Amps Amplifiers based on integrated circuits |
I wonder if anyone else has ever had one of their samples from Nat. explode...
I have just finished hooking up my LM4780 amp and it has just fried the chips. I checked over and over the supplies, and again afterwards. They are correct, but the chips are toast. No problems with the caps or anything else. Supply is 36.8v. This is my third one, but my first LM4780. Boards are from Daniel, I wonder if i set it up right, for parallel? I have never had anything go wrong before, oh well just as well the chips were samples.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX. |
#2 |
This is my layout, probably can't see much from these pics
#3 |
Another pic of the front..............
#4 |
Daniel has mentioned that the LM4780 chips need to be insulated from the heatsink/ground or they will blow. Could that be the problem?
..Todd |
#5 |
Dohhhhhhhhhhhhhhhhhhhhhh!
Yes that is the exact problem............. I will just have to try and get another set from somewhere......... Cheers Taj
#6 |
God it makes you angry when you do something sooooooooooo simple and stupid.....
#7 |
Well if it makes you feel any better, I would have done the same thing if I hadn't seen Daniel's warning. His website schematics were updated recently to mention this.
..Todd |
#8 |
so where was the err? you shouldn't have used screws to hold it together??? please be more specific so I don't make the same simple mistake.
#9 |
Well you have to use an insulator between the chip and heatsink, and also use the bushings that insulate the screws from the chip.
I suppose you could, alternatively, insulate the heatsink from ground but this would be a little dangerous in terms of potential accidental shorts. I'm pretty much a newbie so I can't offer any more details than that. I'm sure the gurus can elaborate. ...Todd |
#10 |
Next time I will just place an alluminium bar right across the two chips and then screw this down to the plate, this with cut any need to screw the chips directly. Plus of coarse the use of unsulation.
| LM4780 SS Pcb | pinkmouse | Chip Amps | 86 | 16th April 2012 06:45 AM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 08:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 06:13 AM |
| Page generated in 0.13581 seconds (59.55% PHP - 40.45% MySQL) with 11 queries |
