| Chip Amps Amplifiers based on integrated circuits |
#11 | |
Naaah, the whimp 2.3 litre turbocharged straight-4 Mustang Opec edition you mean. Same as in the Arab ed. Thunderbird Coupe, what a joke. The idea was to have an optional V6 instead of the 302, but that decision was fortunately cancelled. NBCI, be it GTs or GC's.
Looks like Sponge Bob has killed another thread. |
#12 | |
Some might infer from the above that the gain of a chip-amp depends on supply voltage - It doesn't. Supply voltage sag will only limit the maximum output. If the amp is running at much less than max, supply sag will not matter one iota. True ? Frank |
#13 | |
FWIW, National Semi has said recently that the input coupling cap can have a dramatic impact on sound quality. 2) -- the ultimate gain (of any amplifier) is limited by the supply's ability to maintain its potential -- there are two control loops in a chipamplifier -- that controlled by Rf/Rg and that determined by the impedance of the power supply. |
| Help with first Power Supply for LM1875 | simonlarusso | Chip Amps | 105 | 10th July 2010 12:29 AM |
| LM1875 power supply question (easy) | madisonears | Chip Amps | 12 | 24th February 2008 10:41 AM |
| Power supply for 5 LM1875's | mangrovejack | Chip Amps | 10 | 24th April 2005 07:59 AM |
| Power supply capacitors | wchick | Pass Labs | 12 | 12th August 2002 05:26 PM |
| Page generated in 0.15491 seconds (47.14% PHP - 52.86% MySQL) with 10 queries |
