Old 10th June 2006, 12:40 AM   #1
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Default Gain / supply rails query
I'm looking for opinions on a somewhat odd pairing of variables.
From what i've read since i got hooked on NatSemi's line of amp chips, the LM1875 and the LM3886 sound a certain way at certain voltages and/or at certain gain settings.
I'm set on making a pa-150-like amp for the mid-bass driver for an active 2-way (3xLM3886, paralleled). This one's gonna be "fueled" with about +-30V, although i'm not entirely decided on the gain i'll use (20 or less - 16-18).
Each of the tweeters will be powered by an LM1875. I *might* power these with less than the +-30V for the mid-basses (possibly by regulation), and i'm pretty much set on lowering the gain on these (ZeroOne on the Gainclone forum seems to have experienced improvements on the high-end of the frequency spectrum this way).
Anyone else have confirming / conflicting opinions or advice???
Old 10th June 2006, 08:01 AM   #2
AndrewT is online now AndrewT  Scotland
compare the actual sensitivity of the treble and mid/bass drivers in their finished cabinet. Use this info to determine if you need a different voltage drive from the treble amp and mid/bass amp.
eg. treble 92db/2.8V & bass/mid 86db/2.8V the bass/mid needs double the voltage (-6db relative sensitivity) to give equivalent output.
I would try for equal gain in all amps and use attenuators to adjust volume into each channel. Many crossovers arrange for active/passive attenuation on their outputs.
When you reduce the gain across a chipamp (or opamp) you increase the risk of instability. Take care to follow the manufacturer's or experienced builder's advice if you go for unusually low gain through your chipamps.
regards Andrew T.
Old 10th June 2006, 09:21 AM   #3
The actual level/sensitivity matching will be done in the active crossover. My question actually was something along the lines of "Which configuration is known to sound better?"
Old 10th June 2006, 10:47 AM   #4
PS: As far as i know, big (-ger) supply caps are recommended for optimising low-end response of the LM series, and small (-er) caps for better midrange/treble.
ESP P3A with higher supply rails Flavio88 Solid State 20 29th September 2007 10:49 AM
Gain amp after xover Query mikee55 Parts 0 5th January 2006 09:58 PM
Regulated supply rails for amp - as big as you want. Circlotron Solid State 32 22nd January 2004 01:24 PM
Lower supply rails for this amp? mik Solid State 4 11th June 2003 10:22 AM
Opamp with x10 gain and bootstrapped supply rails. Circlotron Solid State 4 29th March 2003 07:33 AM
Page generated in 0.10903 seconds (65.27% PHP - 34.73% MySQL) with 10 queries
