Old 9th June 2006, 12:18 PM   #1
Default LM 4780 Mono
Hello,
I wanted to build an 3886 amp, but never had the time.
I dindn't buy any parts yet.
Now I heard about the new 4780. As I have also 4 Ohm speakers,
as my old Canton 3-Way with 10 inch woofers, I'm afraid a single 3886
might have not enough power to control them properly.
So i wonder if the 4780 with both channels parallel will be suitable for me?
How ist the sound of the 4780 compared to 3886 and TDA 7293?
Does paralleling affect the sound?
Are there known problems?
What do you think about a simple disign like this?
http://www.chipamp.com/lm4780.pdf
I think about soldering the few parts directly at the pins to spare
a PCB...
Old 9th June 2006, 12:28 PM   #2
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
If you are new , i would recommend the simple single chip/channel design with 3886. The 4780 is two 3886s combined in one package.
LM3886 would drive 4 ohm loadspeakers without problems , if the supply voltage is not too high and adequate heatsink is used.
You can squeeze a bit more power from 4780 in paralell configuration.
Lukas.
Old 9th June 2006, 04:59 PM   #3
I'm not a total newbee, but I do not have many experience with audio.
But I often read people find that the single chip has problems to drive speakers with big woofers/control the woofers.
I think many people who are very satisfied with single chips use them only for smaller 2-way satellites who are supported by subwoofer(?)
So why not use a 4780? Is it more delicate than the 3886?
Stephan
Old 9th June 2006, 07:35 PM   #4
I have a 3 way speaker system with 12" woofers.I have never had any problems. What do you mean "control woofers" ?
I think the choice between single or paralell design is mainly your power reuirements. Note that 2xLM3886 would be slightly more powerful than 1xLM4780 because the latter one in a single case cannot dissipate as much power as two 3886s.
Lukas.
Old 10th June 2006, 05:35 PM   #5
I mean the ability of the amp to damp down the drivers transient effects.
Old 11th June 2006, 05:04 AM   #6
es44 is offline es44  Denmark
es44's Avatar
I use my lm3886 to drive a pair of Infinity Kappa 8.2i, and they're known for being very "hungry" speakers, but i have no problems whatsoever.
It's a joy to play my old vinyl on this setup, really dynamic and with plenty of punch in the lower end.
Just my two cents.
Have a nice day
difference between mixed mono and summed mono Clipped Car Audio 4 10th October 2007 11:34 AM
LM 4780 Mono Amp NEWBIE Dominick22 Chip Amps 1 25th November 2005 05:20 AM
Single Mono's or Dual Mono? Tazzy Pass Labs 8 3rd October 2002 02:03 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.08577 seconds (76.21% PHP - 23.79% MySQL) with 10 queries
