Old 7th June 2006, 03:17 PM   #1
Default TDA7293 Based amp
Hi I am in the proccess of building a amp based on the TDA7293. I am planning on using 2 per channel. I was wonder how do people that used them think they sound? This is my first DIY build and it is using mostly salvaged components from an old amp. I probably don't have enough filtering in the PS because I am only using 2 10000 uf caps. But I plan on doing upgrades to it after I am done building it. it is probably gonna have alittle bit over 60V power rails. These little chips are a pain in the *** to desolder any tips?
Thanks,
Silverchris
BTW: This looks like a great site so far!
Old 7th June 2006, 03:29 PM   #2
Did it Himself
richie00boy's Avatar
I don't think you really want to use 2 per channel? That would mean 4 chips for a stereo amp.
10,000uF PSU is fine.
After having used desolder braid I would never attempt desoldering with out it now.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 7th June 2006, 04:29 PM   #3
This is what I am using for a schematic. Exept with only 2 of them instead of the three. I have tried desoldering braid on them but it is still being a PITA lol. I guess it will be a fight all the way with them. That is good to here about the PSU
Thanks,
Silverchris
Old 7th June 2006, 04:37 PM   #4
Woops the transformer I am using is only a 25-0-25 lol and I cant see why when it is rectified it comes out to around 70 but that is for another thread.
Old 7th June 2006, 08:38 PM   #5
Maybe because 50 (i.e. 25+25) * sqr(2) = 70.7 ?
Hope it helps
Christian
Old 8th June 2006, 11:35 AM   #6
ah thanks. I was searching for that formula but couldn't get the search terms right. I was just thinking is that to much power for this chip? DataSheet
Sorry this is my first build and I don't want to blow anything up
Old 8th June 2006, 11:48 AM   #7
Wynand is offline Wynand  South Africa
Wynand's Avatar
I just downloaded the PDF. It says up to +-50V rails so you are ok.
P.S. look in the PDF from ST, there are some PCB layouts for you to use.
Old 8th June 2006, 12:36 PM   #8
I am doing this first test on perf board to see if i like it then I might buy a eching kit from rat shack. Working on the PSU now
Old 9th June 2006, 11:54 AM   #9
speaker is offline speaker  United States
speaker's Avatar
I am blind I guess, I see no way to download your schematic.
Old 9th June 2006, 01:37 PM   #10
Lets Try again This is what I am planning on building. I guess if I want more power all i need to do is get a bigger transformer and more chips and heatsinks
PCB for TDA7293 jbdivx Chip Amps 8 7th October 2010 02:45 PM
need help with TDA7293 weatherlight Chip Amps 19 20th June 2008 12:55 PM
Tda7293 lasstss Chip Amps 2 14th December 2004 04:36 AM
Where can I get a TDA7293??? mfish0305 Solid State 2 18th January 2004 03:19 AM
Tda7293 chengtaw Solid State 0 18th April 2002 01:19 PM
Page generated in 0.11031 seconds (66.41% PHP - 33.59% MySQL) with 10 queries
